Problems with accleration HELP!!
Old May 27, 2009 | 03:07 PM
soxruled0's Avatar
Ok so heres the story i work at a toyota dealership, my 00 maxima one day just wouldnt respond to any sort of gas i give it. from a dead stop punching it it takes two times longer to get up to about 60 on the high way ill cruise around 70 mph and punch it and the rpms will go right to 4300 and wont go much faster then 80 but i can feel the car wanting to go faster but it cant, it almost feels like its bogging down at stop lights and such. today actually i went from a dead stop and was driving normaly and when i gave the car gas the rpms dropped to literally 0 then popped back up to 2400 rpms. I dont know if i have a serious problem or not.I brought it to the shop at work and they said it was the catalytic converter and Y Pipe. They wanted to charge me 2500 bucks just to get that fixed. I went to a friend who works at a shop and he said my serpentien belt needs to be replaced so i did that and im still in the same spot.
I also asked him to look at my CV joints because when i turn right i hear a clicking noice. Yet he said they were fine so im stuck with those two extremely annoying problems that i want to have fixed tommarow im going to change the oil and oil filter as well as the air filter to see if it does anything any kind of sujestions or hints to what you might think it would be would be great.
Old May 27, 2009 | 05:36 PM
xWasX08's Avatar
Did they tell you why it was the catalytic convertor? Is it clogged? .. working at a toyota dealership, they must specialize in toyotas.. not nissans .
Take it to a nissan dealership, have it checked out. When is the last time you changed / cleaned your MAF?
Changing the air filter on your car should help with the acceleration, after the oil change. O and BTW, 2500 for a Y pipe and CC is murder.
Keep us posted.. Hope its not something serious..
Old May 27, 2009 | 05:40 PM
mannetti21's Avatar
My vote is the MAF sensor, common problem....and I'm not just saying that because I'm selling one in the classified section (see my sig)
But no really, replace your MAF sensor. It takes a whole 5 mins
Old May 27, 2009 | 07:45 PM
djfrestyl's Avatar
Suspension Yoda
I also vote for MAF.
Also, please start using punctuation in your posts and STOP posting HELP!!!! in every one of your threads. Most threads are also people asking for help so differentiating your thread from others doesn't help or speed up the advice that you receive.
Old May 27, 2009 | 08:16 PM
madmax17's Avatar
Definitely sounds like a MAF problem. I would try cleaning it first then if that does not fix it then I would replace it. Also, is your "service engine soon" light on?
Old May 27, 2009 | 09:44 PM
BronxSleeperMax187's Avatar
I had A problem like that and it turned out to be watered down gas, just buy some gastank water remover at autozone (2 bottles) and see if that helps, should be about $3 dollars each,and dont fill up where you did last time go somewhere else. Problem went away after for me.... I also had A mechanic tell me it was the converter too but another mechanic (2ND OPINION) told me it was water in the gas tank not the converter so luckily it cost 6 bucks to fix the problem and some good gas (91 octane or more)!!!!
Old May 27, 2009 | 09:59 PM
Feldman's Avatar
does your car slow down quicker than usual when coasting? maybe you have a brake that is dragging. I think it sounds like a maf problem though.
If you do end up needing to replace your y pipe a cheaper option would be an aftermarket cattman or warpspeed one. I am selling my cali spec warpspeed y that has about 8k on it, i dont know what a used y pipe is worth but i'm sure we could work something out thats fair.
Old May 28, 2009 | 07:24 AM
soxruled0's Avatar
Well when I talked to the people down at the Toyota dealership they said that it the CAT was clogged and the Y-pipe was rusted. They said its making my exhaust louder( I asked them if they saw the after market cat back on there and they had no idea what i was talking about).
I do not think that it is the brake dragging because it stops the way it normally does. If it were the MAF how much are they usually and whats a quick way to clean them? No lights are on in the car like the check engine light or anything that's the only reason i don't think that its a major problem. I don't have a lot of time to look things up I have my last and worst Final tomorrow. I looked at mannetti21's MAF that he has for sale and mine looks nothing like that. I think over the weekend ill shoot a video of the car to see what you guys think.
P.S I'm Sorry about posting HELP!! on all of my threads
Old May 28, 2009 | 08:08 AM
Feldman's Avatar
the cheapest way to pick up a new maf would be DaveB you can contact him here (http://forums.maxima.org/members/daveb.html) or maybe someone else can come up with his number
but first i would try cleaning the maf which is outlined here:
http://forums.maxima.org/5th-generat...10-w-pics.html
Old May 28, 2009 | 08:50 AM
soxruled0's Avatar
Okay thank you ill try that tonight and see how it works and if not ill shoot that video and see what you guys think.
Old May 28, 2009 | 01:22 PM
AEMAXIMA01's Avatar
If you only have 58k, your catalytic converter should be covered under the 8yr/80k emissions warranty. Take it to nissan and have them check it out if the MAF isn't the culprit.
Old May 28, 2009 | 01:24 PM
2kMAXIMAGXE's Avatar
You need a new MAF
Old May 28, 2009 | 03:41 PM
soxruled0's Avatar
I am positive that I need a new MAF. I just changed the oil and air filter on the car and already Ive noticed more throttle response. Tomorrow i will clean the MAF and see how is goes.
Old May 28, 2009 | 09:47 PM
mannetti21's Avatar
keep me in mind if the cleaning doesn't return your power, $60 for a pretty much new MAF
Old May 29, 2009 | 12:07 AM
maximase86's Avatar
I love lamp.
A clogged cat could would match the symptoms. It could be the MAF, but I only think it might be part of the problem. However it couldn't hurt to clean it to start off. Any smell of rotten eggs or black smoke out the back?
S
Old May 29, 2009 | 07:39 AM
soxruled0's Avatar
There is no smell at all, I am about to clean the MAF right now and see how it works
Old May 29, 2009 | 07:58 AM
soxruled0's Avatar
Well I just cleaned the MAF, and it didnt really do anything. looks like ill be buying a new one. At least I get 45% off any part at this auto parts store so looks like ill be making them a visit today.
Old May 29, 2009 | 08:26 AM
djfrestyl's Avatar
Suspension Yoda
Disregard this post.
Old May 29, 2009 | 09:02 AM
karoll's Avatar
MAF is the problem....gl
Old May 29, 2009 | 10:22 AM
soxruled0's Avatar
No i was actually able to order the MAF from the store for $44, it didnt seem like a bad price for a brand new MAF
Old May 29, 2009 | 11:29 AM
xWasX08's Avatar
Wow good deal.. thats cheap...really cheap
Gl w/ install...
Old May 29, 2009 | 11:42 AM
tooreckless00's Avatar
It sounds like MAF. thats my guess from what the problems are.
MAF is dealer only...
and since when? ive bought one from an auto parts store
Old May 29, 2009 | 12:09 PM
djfrestyl's Avatar
Suspension Yoda
Guess not, my bad.
Old May 29, 2009 | 01:47 PM
omartopsecret's Avatar
thats funny
i have the opposite problem that you have with your car. the only thing that my problem is much worst. when i start my car in the morning and step on the gas the car will start to stall and if i tray to go faster it will get stuck in the 3000rpm for a couple sec.. and then it will go to the 5000 and 6000 once it gets there it doesn't change gears until i let go of the gas, if i don't let go of the gas it will stay on first gear for a long time. once it passes first gear it starts to run a little better it gets all the other gears good but it takes a log time to get to 100 when before i used to get to 140 with no problem that's when my maxima was at its prim lol
Old May 29, 2009 | 04:10 PM
djfrestyl's Avatar
Suspension Yoda
^^You realize that your problem could be your MAF as well, right?
Old May 29, 2009 | 06:02 PM
AEMAXIMA01's Avatar
Did you buy an aftermarket MAF adapter or was it OEM through the store you bought it from?
Old May 29, 2009 | 08:50 PM
soxruled0's Avatar
What i did was i got an aftermarket MAF adapter and new MAF so that i can make a custom shorty intake I still have another problem with the car while I'm turning right I hear a clicking noise but when I am driving along at about 35-40 it turns into a scrapping noise. I had my friend look at it and he said that the CV joint (BOOT) looks fine so maybe its underneath the ruber boot.
Old May 29, 2009 | 08:52 PM
djfrestyl's Avatar
Suspension Yoda
If it ends up being your axle, get it from NOWHERE except www.raxles.com, regardless of your auto parts hookup. Their quality is unsurpassed. This is something worth spending the money on.
Old May 30, 2009 | 01:19 AM
I'm going to clean my maf sat.. i hope that is the problem now that i thing about it, that could be the problem because i have a cold air intake and i never change it when it rains probable its really dirty.
Old May 30, 2009 | 01:31 AM
if you car is clicking when you torn 100% of the time its you axles. and for the scraping it could be your wheel Bering or its your break sensor that pis of metal that the brake pads have to let you know that you need new brakes. hey soxruled0 how many mails douse your car have? the reason I'm asking its because i have dos problems too and i have 150000 on my baby
Old May 30, 2009 | 08:33 AM
soxruled0's Avatar
My car has 58945 miles on it. It was my grandparents car before mine, all i do is drive it from my house to school which is maybe half mile away. The interior still looks mint, ill have pictures of the car up soon. If i ordered those axles how hard would it be to install them
Old May 30, 2009 | 11:13 AM
its not that hard to change your axels if you have power tools. but if you don't you are going to have to put a little muscle to it.
Old May 30, 2009 | 11:26 AM
this web site should help you with you axles http://www.ehow.com/how_4668557_axle...drive-car.html
Old May 30, 2009 | 11:28 AM
this one it on the same web site but it gives you more info hope that it helps you
http://www.ehow.com/how_4498141_axle...drive-car.html
Old May 30, 2009 | 11:43 AM
djfrestyl's Avatar
Suspension Yoda
This post gave me a headache. Please please PLEASE use proper spelling and punctuation.
Old May 30, 2009 | 11:45 AM
djfrestyl's Avatar
Suspension Yoda
Here's a Maxima specific how-to site. It even has a perfect how-to for axle replacement on your car.
http://www.motorvate.ca/mvp.php
Old May 30, 2009 | 12:26 PM
thank you for the site, sorry for the spelling
Old May 30, 2009 | 08:43 PM
soxruled0's Avatar
I just don't understand how my car has such few miles and has so many problems. I've been tempted to buy a new car, but I just love the maxima when it runs well.
Old May 31, 2009 | 06:26 PM
i just clean my maf sensor today, its running like a NISSAN MAXIMA GTR THANKS TO ALL OF YOU
Old Jun 7, 2009 | 02:57 PM
maxximaa's Avatar
what did u use to clean it?
