Claybar..... What does it really do?
Old Nov 23, 2001 | 08:02 PM
Molpus
Can someone tell me what a claybar does? Would it help on new 2K1 MAX with bugs and stuff on front bumper?
Old Nov 23, 2001 | 09:10 PM
MaineI30's Avatar
Re: Claybar..... What does it really do?
no, don't use the claybar for bugs. it's a waste of the claybar. It's for more deep-cleaning of the vehicle's paint surface -- it removes contaminants and little bits of things that get into the paint surface that are hard to remove otherwise. works pretty good, smooths the paint right out
Old Nov 23, 2001 | 09:40 PM
Dario's Avatar
our paint has pores in it just like our skin, the claybar just gets in those pores kinda like a deep clean
Old Nov 23, 2001 | 10:16 PM
Molpus
What major retailer can you pick one up at and what do they usually cost?
Old Nov 24, 2001 | 06:37 AM
Maxima-Ness's Avatar
Well, I used the claybar on my 2K and I loved the results. I had a problem with my bumper. I guess during shipping it got loaded with rail dust. No matter how much I cleaned it it would not come off. So, After using the claybay, it came right nout, no sweat, and looks like I just painted it. Also, about a year ago I had my car professionally detailed and somebody sprayed something Im sure they shouldnt have on my rear window and it wouldnt come off, not even with citrus stuff. The claybar took it right off.
There are all different kinds. You can find the mothers at PepBoys or even WalMart, but Id suggest going with either the Zaino or what I use, the Polyclay. Its made by Pinnacle and you can get it at www.properautocare.com . Youll love it. It come with 3 bars, a microfiber towel and a big bottle of lube for the clay.
Old Nov 24, 2001 | 11:10 AM
killrwheels's Avatar
It is great when used in conjunction with a total care cleaning. Wash, Claybar, precleaner, wax, and final detail. I love www.pinnaclewax.com or www.zainobros.com and both offer claybar with many superior cleaners.
Pinnacle = DEPTH OF PAINT
Zaino= FINISH CLARITY
Old Nov 25, 2001 | 09:43 PM
adman's Avatar
Be advised though, a Claybar actually "sands" off the contaminants! If you use it enough, it will eventually remove all of the clearcoat down to the basecoast. It is like dermabrasion...only your car can't grow a new layer of skin.
ADMAN
Old Nov 25, 2001 | 11:18 PM
AznWontonboy's Avatar
Re: Re: Claybar..... What does it really do?
ADMAN
where u hear this?
Old Nov 26, 2001 | 04:09 AM
2maxgarage's Avatar
How do you use clay on the car? I'm having a hard time visualizing dragging a block of clay across the hood without leaving a trail.
Do you use water as a lubricant?
I'd like to give this a try, as I also have that "rail dust" syndrom on my white bumpers.
Old Nov 26, 2001 | 04:39 AM
Cisco's Avatar
Is it recommended to Wax your car after u apply claybar?
GC
Old Nov 26, 2001 | 06:22 AM
UMD_MaxSE's Avatar
Got Bent?
GC
yes
Old Nov 26, 2001 | 07:43 AM
Tanman's Avatar
The Meguiar's clay bar comes with a bottle of Quik Detailer spray that you spray, then rub the bar over the wet area. Works pretty well. Smells good too.
Old Nov 26, 2001 | 09:38 AM
adman's Avatar
Re: Re: Re: Claybar..... What does it really do?
Originally posted by AznWontonboy
where u hear this?
What do you think a Claybar is? It is a bar of clay!
It is made up of tiny pieces of dirt and works like ultrafine sandpaper.
The lubricant allows the bar to float on top of your paint so you only
"sand" off the contaminants sticking to the paint itself.
[------] <- Claybar
^^^ ^^ ^ <- Contaminants
======== <- Paint
ADMAN
Old Nov 26, 2001 | 11:24 AM
GregP's Avatar
I will just add my endorsement of the clay bar technology as well. This stuff WORKS. I used the Mother's clay bar on my '99 Maxima and it made the paint as smooth as a baby's ****. You must remember to wash the car thoroughly first, then use the clay bar + lubricant, then polish, then wax. You can skip the polish step if your paint si already in good condition.
It gave my black car a mirror-like finish.
Old Nov 26, 2001 | 11:34 AM
GregP's Avatar
Old Nov 26, 2001 | 01:42 PM
Ive only used the Pinnacle Polyclay, but im sure the process is the same. It wil come with or instruct you to purchase a spray bottle of clay lubricant that you spritz onto the car. Then you "firmly" run the claybay up and down the cars surface. It really works, believe me. Its hard enough keeping a black car clean and this helps.
Old Nov 26, 2001 | 02:17 PM
PrinzII's Avatar
OG and counting...
Clay bar: Used to remove bonded contaminants in the paint (e.g. rail dust, industrial fallout, overspray).
Use: Some clay bars come with a quick detailer (e.g. Meguiar's, Mothers, Pinnacle), others require using good ole' soap and water as a lubricant (e.g. Zaino). Spray a 2' by 2' area and rub the clay in the area until it becomes slick. After that, wipe the area dry with a clean terrycloth or microfiber towel.
Where to buy:
www.pinnaclewax.com
www.autodetail.com
www.tacscar.com
www.zainobros.com
Retail:
Pep Boys
Autozone
Super Trak (Since they are going out of business, you might get a good deal on one.)
Do you wax/polish afterward?:
Yes. The wax adds a level of protection to your handiwork. But if your car has swirl marks, I would advise using a swirl mark remover (e.g. 3M, Meguiar's Swirl Mark Remover 2.0) or something a little stronger (e.g. 3M Finesse It II) if the swirls are severe. After that step, then apply the polish and wax of your choice.
The vehicle shown here (http://www.autopia-carport.com/forum...5&pagenumber=1) is my '94 after the following:
a) Washing with Dawn
b) Claying with Mothers Clay Bar
c) Applying 3M Finesse It to remove some hazing from sanding
d) Applying 3M Swirl Mark Remover
e) Applying Klasse All In One twice
f) Applying Klasse Sealant Glaze once
g) 5 hours of labor
