Which H3 fog bulbs are you using today?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
for the map lights and the courtesy door lights, now does anyone know what size bulb goes in the visor ?
And finally (famous last words), here we have the $15 Litech H3 bulbs in EBay aftermarket replacement fog lenses, with amber LED's in the daytime runners, and the fog-light rewire trick so the fogs run without the low beams.
It's not knock-me-down awesome, and it's not perfect, but it's a better look than stock, and I'm pretty happy... for now.
Hey Knight if your going to pickup a couple of those vanity bulbs, would you mind grabbing a couple for me as well ... I really like the look of the white LED top markers in the head lamps.
shoot, I already ordered them. I didn't see the post. Here's the link for the vanities I have bought lot's of led's from this guy jpwarden. bty you need 4 of them
http://cgi.ebay.com/ebaymotors/1pc-3...Q5fAccessories
and for the refractors
http://cgi.ebay.com/ebaymotors/2x-T1...Q5fAccessories
However, the 12-bulb LED wedges do not fit well. Maybe well-enough to hang on, but I didn't trust it.
I'm pretty sure they fit ok, I may have had to put them in on an angle or line them up with the slot cut in the opening of the hole.
I had the 12's in there as well but you could count the leds when you looked at the lens and I didn't like that. And they just barely fit in there
- The festoon was more like 35mm, not 31mm. I had to bend the connector plates to fit.
- The panel of bulbs was too thick to fit under the light cover without jamming it un-centered and cutting the light housing.
- They were actually too bright. (subjective)
- And 6 of the bulbs would not light.
Big fail. Bummed.
Got these lights today. Not happy.
Big fail. Bummed.
Big fail. Bummed.
It's... interesting. Certainly different. Kind of otherworldly at night.
(And this is the last time I quote my own posting. Feels wrong.
That's not a particularly good feature in a fog light bulb.
I'm a few weeks now into these $15 Litech bulbs, and am still very pleased with the look and price.
I went to kragen and they said no refund or exchange on bulbs. They said it's possibly a bad circuit or a fuse that is too large for the circuit. I guess I have to call it quits for that fix. I haven't checked yet if the lights exploded but they got really bright for a second and then made a pop so I'll just call it an "explosion."
I'm running cheap Nokya yellow bulbs and have been fine.
bunch of questions about HID Plazma Xenon Fogs...
I know that the stock fog light bulbs are 12V 55W and ARE THEY SIZE H1 or H3 ???
If I want to use stock size light bulbs can I only use that specific light bulbs size??
these are the replacement bulbs I want I might even get the white
also note that on the box in japanese it says 12V 60/55 >>130/100W so does that mean I can use these instead of stock without rewire/kit???
check your metal clips that hold the bulb in place, sounds like there may be one side where the clip is making contact with something and grounding out ... take out one bulb from one side and power up the fog lamp that has a bulb in it, if nothing blows the fuse, repeat with the other side to help figure out which side is causing the problem.
Nothing "exploded" per se. Except the fuse, that is. Not really an explosion either, just a wee little snap.
Which Litech's did you get and are you having any issues with them?? I plan getting the super white over cool blue.
However, I've since become concerned about the heat. These are 100w bulbs, where the specs call for 55w. As such, the lenses get real, real hot. Since I became aware of the high temp, I've stopped using my fogs for fear of cracking them. (Ghost has had his for over a year without issue, but he's also very careful with their usage with things like rain and snow.)
Right now, I'm waiting on a set of Amber LED H3 replacements. Those were only $18 (free shipping), and I have an old lens I can experiment with, so I figure I'd see how that looks. It will turn the fogs into a cosmetic-only feature, but that's OK. They may not light the way in an actual fog, but will still forewarn oncoming traffic.
That's the plan, at least. If that doesn't pan out, I'll try something else.
God knows there are lots of options.
I bought the exact same ones that Ghost54 recommended earlier in this thread. They were only $15 (free shipping), so the price was certainly right. The color is about right. Not perfect, but vastly better than the OEM bulbs.
since they run hot its a good thing you pointed that out... I might just order replacement 55W bulbs.
BTW: Whats the Amber LED H3's wattage??
Go to Ebay and search on H3 Amber
Also, there's a long thread about this from a few months ago.
I really like the idea, but won't have a final opinion until I test it out in the next week or two. I believe MIK3 and phatboislim here on the Org are using them right now, both happy as kids in a toystore.
I'll take my chances with the LED's since they run on 1 Watt and run cool.
I pull the trigger on H3 Xeon White LED's $20 for a PAIR is cheap compared to Nissan dealer ship charging $28 for 1 OEM fog light bulb. post some picks when you get yours installed.
Ran into that same conclusion with the back-up lights. Loved the look, but it wasn't functional enough. And back-up lights are kind of important, so I bailed.
interesting. say goodbye to lumens though.
