power door locks, rear defrost, dome light don't work
Old Nov 24, 2015 | 07:30 PM
  #41
elica's Avatar
Originally Posted by coldfear13
Hey, I was changing the trunk light bulb and as I was putting it in, it flashed for a second and went out. Now the Keyless entry remote doesnt work, the key ring light, the door lock switch doesnt work unless the car is on, door step light and dome light do not work at all. Normally I would be able to turn on the headlights with the car off, now they turn on only when the car is on. First thought was a fuse? Will check them tomorrow, but if they turn out to be okay, then I would have to replace the SECU for sure? Thank you!!
I AM HAVING THE EXACT PROBLEM...DID YOU FIGURE IT OUT AND REPAIR? I AM ABOUT TO SET THE CAR ON FIRE....PROBLEM AFTER PROBLEM...PLEASE HELP
Old Nov 24, 2015 | 07:32 PM
  #42
elica's Avatar
hey, i just fixed mine today, it was a blown fuse #13 in the fuse box inside on the drivers side. The 10 amp one, i replaced it and everything came on, now all works properly.
Do all your interior lights work, and only your headlight wont come on with the car off? Check the fuses under the hood.
everytime i try replacing the fuse it burns out right away...ALL OTHER FUSES ARE FINE
Old Nov 24, 2015 | 08:15 PM
  #43
cornholio's Avatar
^are you using the right fuse?
Old Nov 25, 2015 | 07:28 AM
  #44
elica's Avatar
Yes i am
Old Nov 25, 2015 | 08:07 PM
  #45
DennisMik's Avatar
Fuse # 13 powers the SECU and the SECU plays a part in a lot of things. If you are truly blowing fuse # 13, the SECU is evidently bad.
Here is a drawing of the fuse panel. Fuse 13 is in the middle row of fuses, 2nd one from the left. Is that the fuse that is blowing?
carguy96
20
Feb 6, 2021 06:21 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Huttig2009
Sep 25, 2015 03:31 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
