who has halo's
Old Jul 20, 2009 | 01:00 PM
nzelinsky's Avatar
who has halo's
Hey a question for anybody with halo headlights:
I have an 02 SE with the HID's and I want to get some halo lights. Will these ones work? do I need projector ones or regular and will they work with my factory HID's?
thx
edit: oops heres the link for the ones im lookin at
http://cgi.ebay.com/ebaymotors/2000-...A1%7C72%3A1171
Old Jul 20, 2009 | 01:05 PM
Stormzusmc's Avatar
www.maxpowercustoms.com ftw
there is mine.
Old Jul 20, 2009 | 01:08 PM
nzelinsky's Avatar
oh yeah, I need to buy the prebuilt ones. I cant bake lights and do it myself cuz up here there is really bad winters and humidity will cause condensation build up. Otherwise I would go for the diy ones.
Old Jul 20, 2009 | 01:10 PM
Stormzusmc's Avatar
Dude I'm in Minnesota..just as bad as Canada in the winter and worse humidity during the summer due to the 10k plus lakes here....
You can send your headlights to him and he can seal them up perfectly.
OR if you DIY you can ask him the best way to seal it, and he can walk you through. He will be able to send some OEM sealant along with your order most likely.
IMO the prebuilt ones look like crap, and the projector ones have really useless light....
Old Jul 20, 2009 | 01:27 PM
nzelinsky's Avatar
hmmm... have you tried the prebuilt ones?? It just seems like alot of hassle for me to ship off my lights, considering they are the only set I have and the max is my only car...
Maybe I will try doing it myself, Im just not very good with electrical work and what not... are they easy to wire in?
Old Jul 20, 2009 | 01:29 PM
Stormzusmc's Avatar
Yeah they are simple and he can help you with all the work via email. It would be more expensive to have him do it, but look at his custom prices and services on his website.
Old Jul 20, 2009 | 01:47 PM
nzelinsky's Avatar
alright, well I sent him a message for a quote. thanks for the tip.
Anybody else tried the prebuilt ones? I am still considering this if anybody can give me some feedback.
Old Jul 20, 2009 | 01:51 PM
Stormzusmc's Avatar
the light output on those "ebay" headlights you have posted are going to be garbage and practically useless....it may be easier and cheaper...but they are not good...and thats what most people are going to tell ya
Old Jul 20, 2009 | 02:02 PM
hi-tek22's Avatar
do a custom retro all the way....you wont regret it, those ebay projectors look like the quality is horrible, and when you feel them its even worse............and dont even get me started on the light output.....just TERRIBLE
Old Jul 20, 2009 | 03:56 PM
cmd26's Avatar
dont buy the ebay headlight i did it and i regret evryday i go outside n look at my car. after a while they get real ugly and they use H3 bulbs.
Old Jul 21, 2009 | 08:43 AM
nzelinsky's Avatar
is it hard to wire in the halos? how long do you think it will take if I do it myself??
Old Jul 21, 2009 | 09:48 AM
cmd26's Avatar
I dont have experience with wiring I took my car to a shop n it cost me $150 for them to wire the headlights. Its a complete rewire cuz the factory connnections wont fit the ebay projector headlights connections, they used those caps that r used to connect wires. At one point the connections failed n I only had a foglight at for a whole night it n had to go back to get them rewired for free of course, then they werent aimed right one side was up n the other was down. If i could go back in time I would stop myself from buying n installing those headlights, but hey u might like them its ya choice.
redrelyt12's Avatar
I have the ebay style headlights, they weren't purchased on ebay, but they're the same design as the ones. As for the halos, three of them have died in the year since I've had them. Light output was MUCH better than my fogged stock lenses, but I wish I had saved and am currently saving for an 02-03 conversion with the max power setup.
Old Jul 21, 2009 | 09:50 AM
redrelyt12's Avatar
I had some of the same problems. My wiring was done correctly, the halos were just spliced into the side markers, worked fine till they started blinking and eventually dying altogether. Aiming was a small problem, but easily adjusted.
Old Jul 21, 2009 | 10:11 AM
cmd26's Avatar
my driver side is still higher than my passenger side, i turn n turn i cant get them even at all. clockwise is up n counter clockwise is down at least i think
Old Jul 21, 2009 | 01:17 PM
steroidjunkie's Avatar
get umnitza thin line...
Old Jul 21, 2009 | 02:41 PM
nzelinsky's Avatar
bump- Anybody have experience with LED vs. gas lights for the halo?
Old Jul 22, 2009 | 07:41 AM
M1RAG3's Avatar
the standard ebay projectors come with 2 LEDs in each ring. Any LED system (except for the new umnitza ones which use many small LEDs) has problems with light dispersion in the sense that some parts of the ring will be brighter than others.
LED rings CANNOT compare to a CCFL system, they are just SO dim. Not to mention the fact that LEDs are not meant to be used in high temperature environments (like a headlight housing) and this causes them to fail like crazy (in my experience).
There are some ebay projectors that use CCFLs instead of LEDs...I dont know what the CCFL reliability is for those headlights but I think its worth the chance considering if you get the LED ones you will have about 6 months before you need to open up the housing to fix your LEDs. When mine blew...I just put in a custom CCFL system and I could not be happier with how the DIY turned out
Old Jul 22, 2009 | 08:16 AM
nzelinsky's Avatar
you did the custom ccfl on the ebay lights or your oem lights? So there is a concensus that the diy is the best way to go? Well, Im off to see if I can find a decen writeup for it. Thanks
Old Jul 22, 2009 | 09:55 AM
M1RAG3's Avatar
custom ccfl on the ebay projectors. My car is an '00 so it doesnt come with OEM lights that are compatible with angel eyes.
Old Jul 22, 2009 | 12:21 PM
nzelinsky's Avatar
okay so I found some more prebuilt halos. Anybody think any of these are better than ebay ones??
http://www.kbcarstuff.com/00_03_NISS...max00hjmks.htm
http://www.tumadreracing.net/store/i...oducts_id=1000
http://www.mytightride.com/nissan-ma...eadlights.html
http://www.yourhotcar.com/prod/Custo...dlights/18243/
The last ones are JDM would they be better quality or are these all pretty much the same as ebay ones?
Old Jul 22, 2009 | 12:23 PM
redrelyt12's Avatar
theyre all the same exact thing as the ebay ones im pretty sure, just called different names
Old Jul 22, 2009 | 12:26 PM
nzelinsky's Avatar
ahh crap... thats what I figured...
So are there any GOOD prebuilt ones that anybody in here is using?
Old Jul 22, 2009 | 01:35 PM
redrelyt12's Avatar
from what i've seen, those are the only ones. i'd recommend sticking with stock, cleaning them, and adding the halos if you want to spend the money
Old Jul 22, 2009 | 03:51 PM
arcueda's Avatar
dannng that amber led strip maxpower is using are sex-y....im also interested in this....ill prob diy
Old Jul 22, 2009 | 06:10 PM
Stormzusmc's Avatar
those are always on, but blink brighter when he hits the blinker...its pretty sweet
dont get the ebay crap if you already have hids....period....
all those lights to include are going to be disappointing...the "jdm" ones you refer too lol...i fail to see how those are jdm, as the cefiros dont have those....they just labeled it jdm to sell mark up the price and sell them.....
again you have hids....ccfls are the way to go....contact maxpower, you would be disapointed...
Old Jul 23, 2009 | 08:07 AM
nzelinsky's Avatar
well I am dissapointed that he hasnt replied to me yet... lol
Old Jul 23, 2009 | 11:50 AM
Stormzusmc's Avatar
what did you ask him? ill see if i can get a hold of him
Old Jul 23, 2009 | 08:10 PM
nzelinsky's Avatar
I asked him to price halos with blacked out housing and extra led strip (around 6") all installed on my stock lights. for 02 w/HID
Old Aug 4, 2009 | 08:02 AM
cdawg36's Avatar
headlight question
hey hopefully you guys could help out...i recently rearended some1 and its in the body shop.i need new headlights becasue the back plastic cracked...(they still work so im guessing the HID ballast or w.e it is is working fine. i have an 02 wit HId , nissan wants crazy amount of money for them, and i dont have that kind of money to spend. I want to upgrade to the HALO style lights but after all the reading i heard that you shouldnt buy the prebuilt halo lights because the lighting is dim etc...is my only option to buy brand new headlights and then the halo kit on top of that?..is it also possible to just buy the headlight without the HID ballast or computer or w.e it is. any ideas or suggestions. Like i said im on a tight budget ecspecially after fixing the rest of my car. thnx
Old Aug 4, 2009 | 09:41 AM
nissandrvr98's Avatar
cdawg-check your local junkyards, ebay and the F/S section on maxima.org to get started. You are correct in that often with aftermarket (esp projector) lights, there is a significant degradation in light output and function.
If money is tight i'd focus on getting working headlights in decent shape and then worry about modifying them.
Orion V2 Angel Eyes are the only way to fly tho
Old Aug 4, 2009 | 10:07 AM
Kquezada28's Avatar
ya dude definitely dont go for any of these, to my i think any light, fog and head lights that are not OEM look cheap and stand out a lot...
Old Aug 4, 2009 | 11:18 PM
Child_uv_KoRn's Avatar
Bad *** Newb
maxpower's shop page doesn't work
halos with the strip are very sexy
Old Aug 10, 2009 | 06:14 PM
cdawg36's Avatar
hey can you give me link to where i can purchase the orion v2 for the max...im only seeing bmw for that product. thnx, im also looking for a front lip while i have to paint my nose, suggestions, links? thnx man
Old Aug 10, 2009 | 06:43 PM
Stormzusmc's Avatar
yeah you got to contact him directly
Old Aug 11, 2009 | 09:40 PM
Deckdout2's Avatar
Play with my balls
Just buy this set of Brand New V2's by Umnitza from me and call it a day. Much better then anything you will find out there.
http://forums.maxima.org/5th-generat...5-drivers.html
Old Aug 12, 2009 | 03:43 PM
yamahaman88's Avatar
umnitza Orion V2's all the way
Old Aug 13, 2009 | 06:53 PM
pro23's Avatar
there is mine.
looks really nice..........
Old Aug 13, 2009 | 08:01 PM
Rood's Avatar
Well I have cheap (well not super cheap) ebay halos..
I had to get headlights asap just because rollin without headlights is not good..
I cant complain. They look good, the headlights are bright.
Here is a pic.
So, idk, they work.
Old Aug 26, 2009 | 07:52 AM
umnitza's Avatar
Former Sponsor
When LED first came out, it was dim.
Then CCFL took over, we've now had 5 years of working with CCFL and while it's good, the new Orion V2 is leagues ahead of any CCFL in terms of longevity, reliability for install, and brightness. Plus, it's the ONE time you open your lights. With CCFL, as some of you experienced, the more you drove it through winter climates the less it worked
