EVAP codes GONE! but now two new codes :( O2 sensor(s) help/thoughts? easyto replace?
Old Jul 25, 2009 | 10:35 AM
6SpeedTA95's Avatar
Guys my evap codes went away and almost immediately i have code P1147 and P0139 which I believe could be the Bank1 rear O2 sensor? Is this easy to replace? how long does it take? Any special tools or does it replace like the one on my trans am did? Just pulls out (via plastic bracket) plug in new one and drive away?
Is the O2 diagnosis the likely cause?
Old Jul 26, 2009 | 08:21 AM
ridinwitha35's Avatar
Interesting...this is not the first time I've seen EVAP DTCs and O2 DTCs in the same post. They may be related somehow.
FWIW, I used to get P0138 (bad o2), P0455 (gross fuel leak), and P1448 (EVAP control valve open).
I changed my EVAP canister & the control valve and the O2 sensor code has not come back in about 200 miles. Also, it seems all of my long term fuel trims are significantly negative (below -4%, sometimes reaching to -12%).
Old Jul 26, 2009 | 04:36 PM
6SpeedTA95's Avatar
Yeah, but I think if it were specifically canister related I'd still have one of the evap codes, those are completely gone since the new gas cap.
I'm wondering if perhaps the EVAP codes masked the O2 issue? Because it was about a week after I put on the gas cap and cleared the ECU that the O2 issue surfaced...
I'm going to replace the O2 in the next couple weeks, I hope to God its not a canister too
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
lux97Max
19
Aug 27, 2015 07:48 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
