Wheel Bearings problems?
Old Jul 26, 2009 | 07:51 PM
soxruled0's Avatar
I have a 00 Maxima, for the past i'd say 2 years when i turn right this scraping noise comes from the passenger side. I started another thread about my CV joints a while ago just I checked my joints and they seem fine. My dad brought to my attention that it could be my wheel bearings. Any thoughts or advise would be great.
Thank You
Old Jul 26, 2009 | 08:03 PM
dsm=power's Avatar
if you have a car jack , jack up the car and pull the tire in and out to check for play
Old Jul 26, 2009 | 08:13 PM
Tee00Max's Avatar
+1
Old Jul 26, 2009 | 08:50 PM
soxruled0's Avatar
what do you mean by pull it in and out, and how much play would there be?
Old Jul 26, 2009 | 08:59 PM
Scottwax's Avatar
That's Mr. Detail to you
Just yank of the top and bottom of the tire at the same time. There shouldn't be any play or any squeaking noises.
Old Jul 26, 2009 | 09:06 PM
soxruled0's Avatar
If thats not the problem what else would cause that kind of noise
Old Jul 26, 2009 | 10:46 PM
jadedmatt's Avatar
it has been doing it for two years?
i had the same grinding noise, twice, and had to replace the wheel bearings. better have it looked at before you lose a wheel. lol
Old Jul 26, 2009 | 11:49 PM
Jeff91SE's Avatar
Id bet almost anything thats what it is. Depending on how much play there is, youll want to replace the hub also because its likely to be damaged because of the broken bearing.
Old Jul 27, 2009 | 03:19 AM
Turbonut's Avatar
Dust shield scrapping on rotor?
Old Jul 27, 2009 | 01:07 PM
soxruled0's Avatar
Well I put it on the lift at work and there was no play in the wheel at all.
Old Jul 27, 2009 | 04:21 PM
SoulEater's Avatar
I was gonna say that.
have you recently changed your rotors or changed your pads?
Old Jul 27, 2009 | 06:17 PM
dsm=power's Avatar
Did you check ball joint, tie rod end link while the car was on the lift? How about the cv joint, are your boots cracked?
matts95max
Apr 23, 2025 10:44 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
