Getting to Bank 2 Sensor 2 (b2s2) Cali
Old Aug 9, 2009 | 09:09 PM
baronvf's Avatar
Pulled a p0158, (Bank 2 sensor 2 Max Voltage)
after replacing my rusted off cat and muffler / exhaust
So I buy a Bosch replacement 02 sensor, some pb buster, and a loaner set of 02 ratchets and thought it would be a simple job
6+ hrs laters...I cant even get to the rusted on 02 sensor, there is not any damn room in there
I tried using a flexi-ratchet to no avail
I tried using a ratchet extension and the first pre-cat is too fat to allow even that tube in there.
I hammered a wrench into a breaker bar (galvanized steel pipe) and that just kept slipping off due to my usage of a vice grip on it earlier.
ANY HELP would be appreciated, I am at my wits end!!
Old Aug 10, 2009 | 05:32 AM
sontakke's Avatar
Was it hot? I had my mechanic remove that same sensor just last week, first time at 130K. At first he tried to put O2 socket on it but it was too hot, so he just used standard 22mm (is it 22mm) wrench on it and it loosened up. The car was hot when he did that and then waited for the car to cool down before removing it. Obviously, when the car is up on the lift, it is less difficult to get to that sensor. It is in awful place :-(
- Vikas
Old Aug 10, 2009 | 07:56 AM
baronvf's Avatar
trying this morning with the 22mm standard whilst cold.
Some say to heat up the threads with a torch, but I just dont know.
Old Aug 10, 2009 | 09:25 AM
baronvf's Avatar
Alright,
thats it.
Im bringing it in. The pain in my elbow says enough is enough.
Old Aug 10, 2009 | 01:08 PM
sontakke's Avatar
Just driving the car makes that sensor hot as hell. Just don't burn yourself.
- Vikas
Old Aug 10, 2009 | 06:41 PM
caremd99's Avatar
I had the same problem. I finally hit the pipe not the sensor with a torch for about a minute and then it was fairly easy to break loose.
my03maxima
Jul 28, 2024 07:40 AM
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
