What is this?
Old Aug 12, 2009 | 06:59 AM
nissandrvr98's Avatar
What is this?
mine is rusting out and i need to know what its for?
Old Aug 12, 2009 | 07:00 AM
LA02MAX's Avatar
Oil cooler line...
Old Aug 12, 2009 | 09:14 AM
k..that was one possibility we had discussed.
anyone replaced one of these-im assuming ill leave this to my mechanic
Old Aug 12, 2009 | 09:24 AM
klemenz's Avatar
considering it plugs right into the oil filter lol
Old Aug 12, 2009 | 10:36 AM
Im referring to the metal line itself-not the rubber hose OR the oil cooler itself at the seat of the oil filter. Just needed a confirmation before taking next steps.
ill get a pick at lunch here and try to put it up.
Old Aug 12, 2009 | 11:03 AM
P. Samson's Avatar
The coolant line running forward is returning coolant to the pump inlet and the tube at the rear of the cooler is the coolant supply from the block.
Old Aug 12, 2009 | 11:11 AM
Whitebread's Avatar
Your car is much less rusty than mine. how many miles do you have?
Old Aug 12, 2009 | 11:50 AM
my 02 has about 122,xxx on it-its odd tho-some bolts, lines etc are oddly corroded and others are not and this car came from NC so its just wierd. Carfax was clean when i bought it so who knows.
But this coolant return line is rusting out bad (not leaking yet*knock on wood*).
Im thinking i could probably tackle this one myself.
Old Aug 12, 2009 | 11:54 AM
vball_max's Avatar
I just noticed last weekend that mine is rusting really badly as well, along with my lower oil pan which is actually leaking......
My real reason for this post though is why the hell do you have a fram oil filter on there??!?!?!!?!?!!!!!!!!!! I think I would worry about replacing that first!
Old Aug 12, 2009 | 12:09 PM
thats not my car-its just a representative pic i found haha
seriously tho-has anyone done this before?
Old Aug 19, 2009 | 03:06 AM
blbrizzi1's Avatar
Sure??
Brent
Old Aug 19, 2009 | 06:42 AM
ridinwitha35's Avatar
Originally Posted by blbrizzi1
Sure??
Brent
I happened to be looking at PS belt replacement hints recently...
http://maxima.theowensfamily.com/udp.asp ....4th row of images...on the right.
