Check out all my LED mods!
Old Sep 16, 2009 | 07:53 PM
jowo9's Avatar
The Interior
Shifter Lights
...again
-I took the climate control module apart somewhat and drilled 5 holes into the clear plastic piece that distributes light downward and put 5 LEDs in here
Old Sep 16, 2009 | 07:58 PM
jowo9's Avatar
Switches, etc...
-Took apart my headed seat switches and soldered LEDs and resistors in
-did the same with the heated steering switch (took 2 LEDs)
-and the light on the dimmer
-This is the switch I bought and installed by the shifter where there's a coin holder. It is wired to all of the LEDs in my footwells, and the wiring is hidden under the center console.
-and I put 2 LEDs in the ring around the ignition to achieve this. The light appears more uniform in person than in this pic.
Old Sep 16, 2009 | 08:02 PM
jowo9's Avatar
-I took all of this apart and put red cellophane in here to change the green displays to white
-and the clock. I snipped the dimmer wire on this, because otherwise I couldn't see the clock at night when the headlights are on. Now it's perfect.
...another view
-took the clock apart, cut out the red security light, bypassed the old resistor on the circuit board, and soldered in my own blue LED and resistor.
Old Sep 16, 2009 | 08:09 PM
jowo9's Avatar
-I took apart all the window switches and put in LEDs, and drilled a hole in the back of the door handle and put 1 LED (facing forward) in there.
-in the backseat
-The footwells in the back. I also put an LED in the little handle for the cup holders in the back of the center console. All the pics that I took of my footwells (front and back) really didn't turn out well and don't do justice to how good it actually looks.
-view of the door with bottom light
Old Sep 16, 2009 | 08:25 PM
jowo9's Avatar
-The whole front (not the best pic)
-again from another angle...
The Exterior
-My Umnitza Orion V2 Angel Eyes with other LED plug and play lights (including the fogs) I got from v-leds.com (I can specify which exact ones I got if anyone wants)
-My back up lights (also from v-leds.com)
-license plate lights (from v-leds)
Ok, there are my LED mods I've done in the last while. What do you all think??
Old Sep 16, 2009 | 08:27 PM
zidave's Avatar
Man that is sweet. Love the white clock and buttons
Old Sep 16, 2009 | 08:38 PM
Bjs470's Avatar
Nice...love the white on the head unit and climate control
Old Sep 16, 2009 | 08:52 PM
Tee00Max's Avatar
thats alot of LED's but looks good though...
Old Sep 16, 2009 | 08:55 PM
anomaly117's Avatar
imma copy you with the white display conversion
Old Sep 16, 2009 | 08:57 PM
Stormzusmc's Avatar
not bad - when i have time i will be doing some of the same stuff to along with the speedo
Old Sep 16, 2009 | 09:03 PM
jowo9's Avatar
Yeah, I know it's a lot of LEDs... but I sure like it
Hey stormzusmc, could you tell me how you did your speedo as soon as you do? I don't want to mess it up and that's about the only thing I can still change the lights in and I would... I just don't want to wreck anything... I've pulled it out and started taking it apart before, but I've never wanted to pull the needles off.. I heard you can wreck it by doing that.
Old Sep 16, 2009 | 09:12 PM
nzelinsky's Avatar
man that looks awesome... lets see a write up!!
Old Sep 16, 2009 | 09:17 PM
jowo9's Avatar
I wish I COULD do a write-up, but I didn't think about it at the time (I've done it over the last 6 months or so) and now that it's all done, it would require taking it all apart to take pics, etc. I'm willing to explain any of the steps in detail if anyone wants.
Old Sep 16, 2009 | 09:38 PM
colombian4u_61's Avatar
nice work looks awesome bro
Old Sep 16, 2009 | 09:57 PM
The6spdMax's Avatar
Very nice leds... going to do mine when I am free. Whats the mcd on those blue led? around 8000mcd?
Old Sep 16, 2009 | 10:17 PM
avciugroar's Avatar
jowo... Do you have a parts list for all the bulbs needed?
Old Sep 16, 2009 | 10:41 PM
95 Maxnout's Avatar
Very nice work man.Looks great.
Old Sep 16, 2009 | 11:21 PM
a33i30's Avatar
Wow, great work, I gotta do this too one of these days. I love how you mounted the lights above the ashtray
Old Sep 17, 2009 | 05:54 AM
bigpopaj369's Avatar
my headunit display is white. and wow man that looks really good very clean nice work! i like that alot
Old Sep 17, 2009 | 06:10 AM
KiNgJaMEs's Avatar
Looks good wish i had the time for mods like that.
Old Sep 17, 2009 | 06:29 AM
J-Rod's Avatar
X2. I use to have some much spare time, but now I just get to sit and admire other peoples nice work like this.
Good Job, looks awesome!
Old Sep 17, 2009 | 06:36 AM
Deckdout2's Avatar
Play with my balls
Where'd you get the red cellophane from? Got any extra you'd like to sell to me so I can do my clock and HVAC as well? Looks good for sure! Good job!
Old Sep 17, 2009 | 06:45 AM
Rochester's Avatar
What's that light above your ashtray glowing down on your shifter? Did you create that?
I've been busy this summer replacing a variety of bulbs (numerous times, trying to get a color and brightness setup I'm pleased with.) But you... wow. You've taken LED interiors to a whole new level. Nicely done.
Old Sep 17, 2009 | 06:49 AM
i believe all 5th gens have it they arent bright at all stock i did a led strip in mine. and on finding red celaphane i would love to get some as well
Old Sep 17, 2009 | 07:20 AM
Rochester's Avatar
I just went out to the parking lot to look... OMG, there is a light panel there, and you're right that it's incredibly weak. I need to look at this later tonight, after dark.
Wow... 7 years later, and I just found something on my car I never knew was there. Thanks, bibpopaj!
Old Sep 17, 2009 | 07:55 AM
J2FRESH's Avatar
interior leds mod thats sick
Old Sep 17, 2009 | 08:05 AM
nzelinsky's Avatar
Oh pics aren't always needed for write up.... Can you explain how you did the led strip above ashtray? also, what kind of resistors do you use for putting LED's in all the switches? any chance you can explain how you did the switch and the footwell lighting?
Old Sep 17, 2009 | 08:25 AM
jowo9's Avatar
I'll answer all your questions later today when I have time
Old Sep 17, 2009 | 08:32 AM
nzelinsky's Avatar
sweet thanks. one more, just wondering what bulbs you used for all those replacements and where did you buy all the supplies?
Old Sep 17, 2009 | 08:40 AM
this is my shifter light mod all i used was a $3 12v led strip off ebay this was the middle of the day
Old Sep 17, 2009 | 08:44 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Single #74 bulb facing towards and acrylic diffuser. You can remove the diffuser and make your own very easily using 4 leds and a small piece of acrylic
Old Sep 17, 2009 | 08:46 AM
5mm all the way around; for climate control button indicator lights, 3mm.
Old Sep 17, 2009 | 08:47 AM
AC Moore or any craft store.
Old Sep 17, 2009 | 08:50 AM
metal maxima ur the man! and i got 4mm neo wedge leds for the climate control is that going to be too big?
Old Sep 17, 2009 | 08:51 AM
Yes.
Here's the write up
http://www.cardomain.com/ride/758364/2
Old Sep 17, 2009 | 08:53 AM
Try it. It should be ok. If not, you can dremel out a section of the opening to make the bayonet base fit - just dont' remove too much of the silver solder in doing so.
knight_yyz's Avatar
Toolie
how did you get the clock white? I took mine apart and it still wants to be blue/greeny color
For resistors type resistor calculator on google, type in the number of led's in the string the voltage from the battery, and the voltage drop across the led.
Old Sep 17, 2009 | 08:55 AM
Doesn't anybody actually READ thread content anymore?
Old Sep 17, 2009 | 08:56 AM
ok thanks much appreciated!
Old Sep 17, 2009 | 09:12 AM
nzelinsky's Avatar
nobody reads threads man why would they do that? its so much easier to skip the reading and ask a bunch of questions that are already answered a few posts prior
