Removing offset from rims..
Old Sep 21, 2009 | 07:03 PM
BigOgre's Avatar
Can I take the rims to a machine shop and have them grind away the offset?
This is my simple math..
25 offset (milles) - 40 offset (the mm that Iv seen other milles at) = -15mm, the difference that the shop would have to grind away. correct?
Old Sep 21, 2009 | 07:53 PM
oldngivout's Avatar
Willing to learn
What are you trying to achieve here?
Are you trying to move the wheels out near the fender lip, or in away from the fender?
And BTW, forget about "grinding" anything to change the wheel location. Bad idea.
Old Sep 21, 2009 | 08:34 PM
BigOgre's Avatar
I want to move the rims inward towards the car.
Old Sep 21, 2009 | 09:54 PM
Mu_036sp's Avatar
I vote, Do not mess with that. Thats a engineering move. That rim is made for that offset. idk
Old Sep 21, 2009 | 10:00 PM
Drockb418's Avatar
will you clear the caliper?
Old Sep 21, 2009 | 10:01 PM
Drockb418's Avatar
dont do it btw i cant see any good out of that.
Old Sep 21, 2009 | 10:04 PM
BigOgre's Avatar
A plus offset sticks out like a *****. I don't want it to stick out that much.
Old Sep 21, 2009 | 10:07 PM
Drockb418's Avatar
pics?
Old Sep 21, 2009 | 10:16 PM
BigOgre's Avatar
Yeah i will as soon as I can.
Old Sep 22, 2009 | 12:42 AM
IHAVEA2KMAXIMA's Avatar
Unless the wheel is 10" wide or something, I dont see how it will stick out a lot. I have 9J +25 and they fit just fine. I would actually get lower offset too if I could (for the back at least).
Nonetheless, I wouldn't mill the offset because some wheels are specifically design for the offset, so if you mess with it, there will be a high chance of wheel failure.
Old Sep 22, 2009 | 07:36 AM
knight_yyz's Avatar
Toolie
You would have to machine that material out of there, and it looks like you want to machine 15 MM from the inside face of the rim. This would make the rim very thin there and possibly destroy the structural integrity of the wheel. Your studs would probably be too long, and you might even break through to the conterbore for the lugs, which would mean there would be nothing for the lugs to seat on when you torque them down.
Old Sep 22, 2009 | 08:51 AM
vastmax's Avatar
the most a knowledagle machine shop should remove is 5mm. 15mm is WAY too much, you need to find different wheels.
Old Sep 22, 2009 | 09:01 AM
Feldman's Avatar
i wouldn't mess with it, you are going to change the structural design of the rim which could result in any number of issues. If you dont like how far you they stick out it looks like it's time to buy some new rims with the correct offset
Old Sep 22, 2009 | 09:09 AM
maximase86's Avatar
I love lamp.
Have you tried putting a rim up on the car to see how it looks? I don't see why would want to tuck the wheels in unless they stick way out.
S
Old Sep 22, 2009 | 10:38 AM
BigOgre's Avatar
Yeah i have put the wheels up on the car, I didnt get a change to take pictures though..
Old Sep 22, 2009 | 02:53 PM
k2a2b's Avatar
http://www.1010tires.com/WheelOffsetCalculator.asp
that will give you a concrete answer...don't machine your wheels, you are asking for trouble
Old Sep 24, 2009 | 02:36 PM
BigOgre's Avatar
this is what i had in mind..
sorry about phone pic..
Old Sep 24, 2009 | 02:40 PM
PulsarGTS's Avatar
If you remove that material you remove the surface that the wheel lug uses to holds the wheel again the hub. You cant modify wheels.
Old Sep 24, 2009 | 02:43 PM
Maximized2000's Avatar
Don't do it. Just sell those and get another set of rims in the offsets you like better. Those look like MM Evo5's?
Old Sep 24, 2009 | 02:44 PM
viperboy's Avatar
I guess you're not getting it. As said before...
Originally Posted by oldngivout
...And BTW, forget about "grinding" anything to change the wheel location. Bad idea.
Originally Posted by IHAVEA2KMAXIMA
...Nonetheless, I wouldn't mill the offset because some wheels are specifically design for the offset, so if you mess with it, there will be a high chance of wheel failure.
Again... BAD IDEA.
BigOgre's Avatar
yeah they are the mm evo 5
Old Sep 24, 2009 | 02:50 PM
Um..why would you want to do that to nice MMs.
Ur gonna ruin the rims. Don't do it.
Old Sep 24, 2009 | 02:54 PM
BigOgre's Avatar
I dont want to ruin them, I just feel like they stick out too much
Old Sep 24, 2009 | 03:08 PM
Put them on the car and post a pic. I think we all wanna see how far they stick out from the fender for you to want to grind it down.
Old Sep 24, 2009 | 04:02 PM
vastmax's Avatar
with this said...
I am currently running 19x8.5 +25 Evo5's all around on my 5.5 lowered on Progress. If you are trying to get to 40mm...that is WAY too much.
Since you are so dead set on milling your wheels...i'd mill the front 2 wheels down to +30 (-5mm from what they are now). I have rolled my pass. side fender and still rub with 3 people in the car. If you dont wanna risk rubbing, might as well mill the rears down 5mm as well. This will make all 4 wheels/tires sit as flush as possible to the fenders without rubbing. Also, i'm running 245/35r19's.
As I said before , do NOT go more than 5mm.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
