20's on my maxima, will i run into any problemm???
Old Sep 23, 2009 | 07:37 PM
Mu_036sp's Avatar
Im looking into a set of 20's and its 9.5 inches wide. all tires 245/35/20 with offset of 35. my Maxima is dropped on Tein H techs. so its not that low. will i run into any rubbing of the inner fender or anything??
Old Sep 23, 2009 | 07:55 PM
viperboy's Avatar
That's a very aggressive fitment. Those tires will be stretched too.
Old Sep 23, 2009 | 07:58 PM
Tee00Max's Avatar
you may have to shave that lil tab that holds you bumper and rear quarter panel down a lil, it tends to rub on that lil piece of plastic...what king of struts do you have??
Old Sep 24, 2009 | 12:40 AM
a33i30's Avatar
But but, your car looks so good with stock 17s.
Old Sep 24, 2009 | 04:48 AM
phatboislim's Avatar
^wow...
i want to see teh 20s in thought of being installed, also, they will fit IMO, u just may have rubbing when turning
Old Sep 24, 2009 | 04:49 AM
digitalbow's Avatar
A proper tire size would be like 275/30 if you don't want problems with protecting the rim edge. 245s are not wide enough for a low profile 20". With 275/30 though, you will have rubbing issues in the front for sure, but the offset mitigates the inner fender issues for the rear.
Old Sep 24, 2009 | 04:55 AM
i'm willing to bet that he's trying to get the stretched look on his wheels
Old Sep 24, 2009 | 04:56 AM
and1jr17's Avatar
maybe a little rubbing with extreme turns..
Old Sep 24, 2009 | 05:06 AM
Sterling's Avatar
Stay stock. Your suspension is going to take a hit. I've had 20's for 5 years and the suspension is in diar need of an upgrade. I also just ran springs.
As far as your numbers I would say you might rub and you should roll the fenders. You will be stretched with a 9.5 as well with a 245. +35 should sit pretty flush for you as well.
Again as far as running into problems, just be aware of your suspension and do any upgrades there first before getting 20's. (If you feel something is lacking)
GL and have fun.
Old Sep 24, 2009 | 10:50 PM
Mu_036sp's Avatar
The wheels im looking into are tempting, they are gun metal TSW's with 4 inch lip. and my sig, TE wheels are sitting in the Garage ATM, My car Rolling on some 18" 350z wheels for a little. I like to switch wheels from time to time.
Old Sep 25, 2009 | 06:58 AM
scottygill's Avatar
I say go for it, I have 245/35/20s with stock suspension. The only issues i have are that in the front when making a 'U' turn or 3 pt turn, there is a little bit of rubbing towards the back of the wheel well but it has not effected my tread. The wheel well has worn through tho in that one spot. Ill take pictures this afternoon if it stops raining. The only other problem is that if i have people in my back seat and i go over a speed bump, the rear passenger tire "bottoms up?" and hits something making a brief scuff sound.
As far as spacing goes, the rear tire is pretty much flush with the rear fender, the fronts could use a 20mm spacer
Also you can fit one of your TE's as a spare in the trunk without much problem. i dont know how 3 20's and a 14 will ride if you have a flat
Old Sep 25, 2009 | 08:21 AM
Fred Stone's Avatar
May look OK, but I have to drive on really rough/gravel rioads. I need all the clearance I can get. I'll stick to stock.
Old Sep 25, 2009 | 09:22 AM
Foellarbear's Avatar
iv got 20's and have no problems what so ever.
Old Sep 25, 2009 | 09:38 AM
NissanTun3r's Avatar
You better get your fenders rolled, and anytime you hit a bump you'll probably scrape. And ride quality is going to be horrible.
Old Sep 25, 2009 | 09:46 AM
fitness stain's Avatar
Maxima's look horrible with 20's ... ghetto ****, man
Old Sep 25, 2009 | 09:56 AM
secondtonone317's Avatar
nycnissans
plz dont do it
Old Sep 25, 2009 | 10:03 AM
SuperStasiu's Avatar
wow those rims look facken horrible
Old Sep 25, 2009 | 10:20 AM
woody6212's Avatar
It's been said a million times but to each his own obviously. I have 20's on mine with H&R's and have no scapping issues and have no problems doing a complete U-turn with no scrapping. I am going to get some illuminas next month because the odometer just ticked over to 80k and I'm still with OEM struts. But just like with any wheel I've seen plenty of hideous 17's 18's out there so if you pick a good looking wheel I think you'll be fine.
Old Sep 25, 2009 | 12:48 PM
ButtaMax's Avatar
those are 2 horrible examples!!
Old Sep 25, 2009 | 12:52 PM
viperboy's Avatar
Old Sep 25, 2009 | 07:28 PM
Originally Posted by viperboy
x3
Maxima's are not cars that look good with the whole "dope boi yeah Im ballin in my 10 year old car cuz I got some twankies so look at me" wheels
Old Sep 25, 2009 | 08:31 PM
blktalon456's Avatar
[/quote]
I think it looks good. Just like minw. I have 20x8.5 42 offset with a 225/35. Streteched and looks wonderful. To each his own. I need to lower mine now
Old Sep 25, 2009 | 10:38 PM
User 12822's Avatar
20s in chrome are the ugliest **** you can put on a maxima. why put 20 inch rims on a car that comes with 16/17 stock? its just getto and retarded. put your money into **** that will benefit your car.
Old Sep 25, 2009 | 11:33 PM
Mu_036sp's Avatar
Those are the wheels.
Old Sep 26, 2009 | 12:37 AM
OC guy's Avatar
2002 maxima se
A+++
Old Sep 26, 2009 | 06:57 AM
User 12822's Avatar
Hmm I won't lie the rims look good. But thats on a Z, they just arent going to look right on a max.
Old Sep 26, 2009 | 07:32 AM
lots of people have comment on my 20's sayin they look good and especially with black. I'd got with whatever you like.. i mean its your car you make it the way you want it to look.
Old Sep 26, 2009 | 07:55 AM
Rochester's Avatar
At least you're showing good taste, and not going with over-sized ghetto chrome. Those are gorgeous (on the 350Z).
And that's a big stretch for me... about the only thing I like as much as the stock 17" SE rims are the rims off the G35s.
If you can make these fit without problems, I say go for it.
Old Sep 26, 2009 | 08:51 AM
Merovingian7's Avatar
Yes I agree I think if ppl want bigger then 18 should be good enough. 19 if you wanna push it.
Old Sep 26, 2009 | 05:06 PM
Not everyone wants to beat a Ferrari in 4 seconds flat. Some wanna look good and make a statement. As far as wheel size goes that's why different sizes are made. My car for example rides better than stock and has zero issues. My speedo is still dead on and all. It comes to ratio. Also not everyone wants to be lowered to the ground either. Flame On.
Old Sep 26, 2009 | 05:31 PM
bigpopaj369's Avatar
im not a big fan of anything over 19'' on the 1-5 gens but there is a few exceptions like foellarbear ect ect and the wheels u are going to get look effing sick! giant chrome rims are just ghetto as fug. u just get so sick of seeing smaller cars roll on redic huge rims just makes it look like a tractor going down the road. cars like the 6+ gens that come with mostly 18'' rims plus, it dont look bad to go up a few inches because of the size of the car. there is a kid in the next town over from me with a 5th gen same color as mine with chrome 22s it looks like one of those hi crop tractors so dumb. if u do get them i hope u upgrade ur brakes in some way
Old Sep 26, 2009 | 05:53 PM
Rochester's Avatar
Ricers and Racers... these debates always seem to happen when it comes to rims. Funny thing is, when Ricers grow up, they grow out of being a Ricer. They buy minivans and look back on their glory days.
But racers, the ones that have it in their blood, they grow up and do things like buy high performance 4-door sedans with manual transmissions.
Um, here's another perspective. You can easily ridicule a Ricer just by looking at his silly ride. However, you have to watch the Racer drive before you can mock him out.
I don't know what that all means, but it sounds philosophical.
Old Sep 26, 2009 | 05:56 PM
rochester that was perfectly said
Old Sep 26, 2009 | 06:08 PM
e-subliminal-2's Avatar
Agreed.
Old Sep 26, 2009 | 07:23 PM
Rochester's Avatar
Thanks. For the record, when I was a kid I drove a car with chrome wheels and a screaming chicken on the hood; (yeah, we all know what that car is.) And lot too long ago we did own a minivan for a while... but that was my wife's car
Old Sep 26, 2009 | 09:15 PM
95 Maxnout's Avatar
I would stick with the wheels you have now.Imo 20s are to big on a 5th gen.I love the way the TE wheels look with a nice drop.
Old Sep 26, 2009 | 09:33 PM
OC guy's Avatar
2002 maxima se
i believe anything over 19 inch look better on 300 and charger. but to each his own.
Old Sep 26, 2009 | 09:43 PM
bigpimpen092's Avatar
I got 19 inch g37's staggered and the wall on the back tire is thinner than the wall on the front tire.. its a really sexy look. 245 on the back tires and 225 on the front, bridgestone potenza RE's. I drive in the worst parts of NJ with them and they take a good beating with no problems. I truthfully think that you shouldn't go over 19 inch. You should really try 19 inch. It's only 1 inch smaller and your not going to notice that inch, and it's also a serious ride quality difference from the 20's. The 20's will feel like your riding on 4 rocks and when you hit a hole your gonna be like wtf!!
Old Sep 27, 2009 | 08:39 AM
^^^ ur rims are sex bro nice max
Old Sep 27, 2009 | 09:24 AM
Rochester's Avatar
Originally Posted by bigpimpen092
I got 19 inch g37's staggered...
Out of curiosity, how did you acquire rims off a G37s Coupe? Did you buy them from an Infiniti dealership? eBay? craigslist?
And yeah, they look great. Particularly off the S-Coupe. The non-S rims... not so much. And the 2 different styles on the Sedan... not so much.
But the wheels from the S-Coupe are gorgeous.
