Slow front windows!
Old Sep 24, 2009 | 11:48 AM
chris in va's Avatar
Slow front windows!
Man, considering all I've replaced the past three weeks on this car I hope this isn't something serious.
The two front windows get slow on occasion, but yesterday the drivers side simply refused to go up. It had rained that day so the gasket was wet if that means anything. It did eventually go up after a few button pulls.
Old Sep 24, 2009 | 11:51 AM
Tee00Max's Avatar
same thing with my roomates max man it does the exact same thing, does it make a shreaking noise when it tries to go up??? Sometimes its the rubber between the windows is flipped over and it slows it down.
Old Sep 24, 2009 | 12:14 PM
jrflores's Avatar
my front passenger side does the same thing, it goes up really slowly, and screeching all the way. what could be the problem?
Old Sep 24, 2009 | 12:16 PM
ReasonableDoubt's Avatar
Yeah happens to me also (also on both windows). Does get annoying at times. +1, that it has something to do w/ the rubber. Fixed it once then, it went back to messing up. Haven't found (or tried for that matter...) to find a permanent fix.
Would be great if someone has a fix for this.
Old Sep 24, 2009 | 12:43 PM
unrealii's Avatar
My car does this too. I think I have figured out the problem. Cleaning them helps, but I have noticed that the windows are loose. When raising the driver's side window on auto, grab the window as it goes up and pull it towards the B-Pillar while assisting it up. Mine tend to move back about half way up then seem to move more freely. I think the glass is lose from the frame within the door. Since I have dynamatted the doors, I have been putting off taking the doors apart to check for myself.
Old Sep 24, 2009 | 02:07 PM
BigOgre's Avatar
Spray some lube where the window rolls up and down.. helps..
KY!
Old Sep 24, 2009 | 03:23 PM
woody6212's Avatar
Roll the window down, Get a can of Silicone spray and liberally spray the window tracks down and like BIGOGRE said roll em up and down a few times and blaaammmooo...Windows will roll up and down like new...
Old Sep 24, 2009 | 04:55 PM
metalpiotr's Avatar
03 Maxima, 6spd
I had something similar happen with my driver side window. It was making noise going up, and going slower and slower over the last year or so. At times it would get stuck, and the only way to get it to go up was to hit the door while holding the up button.
The metal track part of the window regulator ended up rusting up. It made the it hard for the window to slide on it freely. This put more strain on the motor. With the motor on its last breaths, I replaced it with a rebuilt motor from NAPA. I also cleaned the regulator from rust a bit, and re-greased it with white lithium grease (in a spray can). Now it works great again. I took some pictures doing it... might post them soon.
Old Sep 24, 2009 | 05:20 PM
Max_5gen's Avatar
Plee-e-e-ase - pictures, I mean .
Old Sep 24, 2009 | 05:38 PM
VQP0WER's Avatar
The track looks like a large 'X' when the window is all the way up.
Old Sep 24, 2009 | 08:16 PM
TheOldDude's Avatar
PLEASE POST YOUR PICS! My car has had this problem for the last 2 years. Last winter (I live in the north east), I never rolled down the windows (even to pay a toll, etc) because I really thought that they would get stuck!
Old Sep 24, 2009 | 08:18 PM
TheOldDude's Avatar
I assume you had to pop the door panel off?
Old Sep 24, 2009 | 08:26 PM
unrealii's Avatar
Yup, not that difficult.
IIRC:
1) Remove screw from door handle/pocket well
2) Remove screw near upper front of door panel - towards door jam
3) Carefully pop out entire window switch trim and disconnect the harness(s)
4) Pop off trim around door lock/handle release
Old Sep 24, 2009 | 08:47 PM
Feldman's Avatar
KY!
NO LUBE! you will have a major mess! use some soapy water to take care of the squeaking windows.
if you put some lube on the seal you will have greasy windows every time you roll it down and up and it will be that way until you take the door apart and clean it all out.
Old Sep 25, 2009 | 09:47 AM
Fred Stone's Avatar
Mine are getting slow on the '98. Will try the soap trick. The '03 has always been slower than the '98, but has never changes speeds from when it was new.
Old Sep 25, 2009 | 04:44 PM
Psyfa's Avatar
used to happen to my front windows...got worse in the winter or any cold weather
I finally cleaned out the track, sprayed some liquid silicone (do NOT use WD40 as it'll attract more dirt), and the windows started rolling up like new.
If that doesn't solve it the window switch may need to be replaced.
If you need to remove the door panel for one reason or another here are some good instructions. They helped me when I was replacing my speakers.
http://forums.nicoclub.com/zerothread/157798
Old Sep 25, 2009 | 07:39 PM
TheOldDude's Avatar
IIRC:
Thanks very much for the direction. I'm doing both front doors tomorrow!
Old Sep 25, 2009 | 08:28 PM
RhodeyMax01's Avatar
I always have to wait for my front passenger window when i put them up..**** takes forever lol
Old Sep 25, 2009 | 08:35 PM
nsnrider's Avatar
that's not entirely true. if you grease just the side rails NOT the horizontal rubber gasket, you won't have any problems.
I use regular grease and a small bush and applied it into the vertical channels. Wiped off the access grease with a towel and rolled the glass up and down a few times. Now they work like new.
Old Sep 26, 2009 | 07:33 AM
Foellarbear's Avatar
i've had some problems here as well.
Old Sep 26, 2009 | 09:26 PM
95 Maxnout's Avatar
Mine goes up and down fine but when I hit the drivers side auto up button the window closes then opens up about a 1/4 way down.I tried closing it automatically again several times with the same result, but if I hold the butten to the up position it closes fine.I wonder if something is obstructing the window or is this some electrical issue???
Old Sep 26, 2009 | 11:36 PM
FlipCpt45's Avatar
mine do the same thing... and my mom's 96 maxima windows go up and down perfectly.... and my friend's 89 maxima doesn't have a problem either... ftl
Old Sep 27, 2009 | 06:57 PM
TheOldDude's Avatar
IIRC:
Alright then --- I popped the door panel off and through the top of the door I can see a metal guide (roughly in the center of the door) that a plastic follower straddles as the window rolls up and down. I could only access the top of the guide so I sprayed some white lithium grease on it and worked the window up and down. Sprayed and rolled several times. Put everything together and now it's worse. What else needs top be lubed? How do you get to it. Do I need to strip off the moisture barrier?
Old Sep 28, 2009 | 06:11 PM
metalpiotr's Avatar
03 Maxima, 6spd
IMO most of the resistance occurs on the metal track of the window regulator ("the metal guide" as you call it). I doubt lubricating the rubber parts or the sides of the window will make much of a difference. In my case the track was rusted up a bit, so i think that's why the window wasn't gliding on smoothly. I think spraying that down is the most you can do without pulling out the regulator.
Old Sep 28, 2009 | 06:20 PM
anomaly117's Avatar
anyone with a 5th gen NOT have this problem? im gonna try lubing the tracks myself.
Old Sep 28, 2009 | 06:47 PM
unrealii's Avatar
Has anyone tried moving the glass how I described in my previous post?
http://forums.maxima.org/7219082-post5.html
I have a feeling that this "play" in the glass is causing the slow windows.
Old Sep 28, 2009 | 09:44 PM
metalpiotr's Avatar
03 Maxima, 6spd
Ok. Here's the thread:
http://forums.maxima.org/5th-generat...-pictures.html
Hope it helps.
Old Sep 28, 2009 | 10:06 PM
MURDRMAX's Avatar
mine does the same thing, ive noticed that if you grab the window at the front and push it to the rear of the door the binding stops. almost like the glass is loose on the tracks.
Old Sep 29, 2009 | 08:52 PM
TheOldDude's Avatar
I'll pull the door panel and soak the track with more lithium grease. I have read a couple of threads where folks have accidentally waxed the rubber window parts and gained good results. I'll plan a dual pronged attack for this weekend!
Old Oct 3, 2009 | 07:03 PM
Adik's Avatar
Hi guys, I have problem with rubber when window goes down it jams rubber from inside and doesn't want to go more, so I have to open up window and try again. today I open my door and tried to clean rubber and window from inside but it became worse. do you know where I can buy a new rubber (it's not just a rubber it also has some mounting and soft material) and what is exact name of that part? thanks
Old Oct 3, 2009 | 10:14 PM
metalpiotr's Avatar
03 Maxima, 6spd
Are you talking about the moulding?
http://www.courtesyparts.com/maxima-...2092_2101.html
I'm guessing that something like that you'd have to get from the dealer... but I could be wrong.
Old Apr 20, 2010 | 11:57 PM
gjaa's Avatar
has anyone got a permanent fix for these? mine actually roll all the way down on their own, no buttons pressed nothing, its almost like my damn window has a mind of its own
Old Apr 21, 2010 | 05:46 AM
2slow's Avatar
For those with slow windows, have you tried to realign the for and aft tracks (listed as front and rear sash)?
I had a similar problem in another car where the track wore/moved and allowed the window to rock fore and aft as it moved up/down. I've noticed my Maxima exhibiting the same symptoms, but haven't been motivated enough to do anything about it.
Old Apr 21, 2010 | 06:05 AM
pepox369's Avatar
have u tried liquid armorall original on the side tracks? clean the tracks a bit and then spray A LOT OF IT.. i did mine about a month ago and since then they roll up and down with no effort.. my windows would get stock before to the point that i had to pull the window with my hand to make it roll up..
P
Old Apr 21, 2010 | 11:49 AM
01-maxima-24's Avatar
My fix
I had the same problem with my passenger window, its was really slow and sometimes didn't go up at all. I had decided to eventually just replace the window motor but a couple weeks ago they(all my windows) started working like new. The only thing I did at the time that could explain it was a very simple ground kit (battery neg to frame, frame to motor). Could just be coincidence but I personally dont think so. Someone else should try, it may be a fix for some of us .
Old Apr 22, 2010 | 01:04 AM
gjaa's Avatar
im going to trying cleaning and lubing the tracks to see if that makes any difference at all, ill post my results after i do it this weekend!
The Frye
Feb 3, 2019 08:34 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
