NEED HELP ASAP, Car will not let me go over 2.4k rpm
Today, Installed new High flow cat and full catback. finished the install. Started it. no leaks. Time to rev. it wont let me go over 2400 rpm. I warm it up. Drove it and will not go over 2400 rpm. checked all my o2's. they are fine. my maf is plugged in. I dont know what to do, I have work 9am tomorrow morning. oh dear. Help me with ideas on what it could be.
could be the MAF crapped out or the TPS crapped out here's a thread that may have some suggestions http://forums.maxima.org/5th-generat...=ecu+limp+mode
If you have a can of CRC MAF cleaner try giving it a good cleaning and then try the engine restart again and ref. http://forums.maxima.org/5th-generat...ht=MAF+cleaner
Sounds like MAF to me.
TPS will usually give you a flat spot, but if you pump or feather the throttle you'll get past it.
Was the MAF disconnected when you did the install?
Maybe reset the ECU before you rush and look for problems.
Since the car is breathing better maybe it thinks there is some sort of problem with the exhaust and it is in some sort of limp mode.
I did the ecu reswap as well as Ahmad_1290. Since mu_03sp isn't here to answer these questions, I was there and i'll reply to try to get him some answers asap.
Maf was on during instal, wasn't disconnected. The ecu reflash we already tried. If you downshift you CAN get past 2400 rpm but you can floor it after and it won't move PERIOD. limp mode? idk..
Check ALL the wiring connections on the engine that you can find, even if you didnt mess with them.
It was same with or w.o the maf plugged, so assuming that's a maf problem. Also it is a 6mt, the pedal procedure was done. ocne you downshift though, lets say u go to 4k, you can punch it and get no where. Everyone pointing to a bad maf, could it just go bad over night like that? Or is the ecu just confused? not tuned btw.
reset the ECU then, if its a problem like explain the car will immediately do the samething... same with my sputtering problem, i reset the ECU and with the CEL being off for a couple of mins the car still acted the same... check for the APPS (accelerator pedal position sensor) code also... IIRC it will cause that problem i forgot the code number IIRC its P2138... i had it with mines also (it just stopped fo some reason)
how many miles? also, mafs dont "go bad" they just stop working. the maf operates off of a thin, delicate wire. so its totally possible for one to $hit out overnight.
when i first installed my injen cai, the same thing happened to me. i got done with the whole install process, tried to get on it, and *chooooooke*. turned out to be the last thing i expected, the maf. so check it.
highly doubt its the tps.
e-subliminal-2: Its not Maf. I cleaned it and did no difference and i have 130k. i have a feeling its my o2's. i extended 2 of them for my headers. so i was told i am having a shorted wire. so im gonna try to get that done soon.
e-subliminal-2 Give me your maf haha. let me see if my car acts different.
let us know what happens
IDK if it will work for you but what I do is drive, once it bounces one time, I stop, shut the car off and then restart and drive again and works fine. The only electrical change I made was disconnected my EGR but i have a 3.0.
Let me know if that makes a difference.
it probebly will be... i was talking to him over the phone and he explained the problem... he was having the exact same problem i was having... nobody here helped me out nor had the solution, it was that one or more bank was running extremely lean because the contact from the extended o2 sensor wire and the wire he uses for extention doesnt have enough contact on it, causing the car to bog and at a certain RPM kicks like you have NOS and acts normal (even causing the p0300 code like i had also)
Your car is in Limp Mode, my friend, which is virtually a "safe mode." It minimizes speed and RPMs in an effort to protect the engine from damage. (If you're familiar with Windows, its like booting your computer up in Safe Mode.)
Mine did the same thing on several occasions. ALL of the dash warning lights lights were on (Slip, Traction, SEL, Transmission, battery, oil, etc) and the car threw about 12 different codes.
In my case, it was the TPS.
lemme see if i can help u guys a lil bit... after 4K rpms his car kicks out of limp mode and acts fine... not a TPS, car not going over 2.4K will most likely be though... can also throw the APPS code, but if it acts fine over certain rpm other problems may be a factor
I'm still shooting for maf. I'm not too familiar with side effects of a bad o2 though, so w.e it is. gl.
Cleaning an already dead maf btw won't change anything. Once it's gone it's gone. You can clean it to TRY to prevent it from going bad if you feel it's weak, but once it's dead you're just beating a dead horse.
what i was posting was not an opinion it was a fact... i never said he had his o2 wires mixed up... basically the wires dont have much contact so while he is driving regular (when the ECU reads from the o2 it will bog, at WOT it wont) i agree, hence why i try to clarify his post based on a phone convo me n him had... it struggles to go past 2.4K but after 4K it will kick and act normal because at that point the ECU isnt reading from the o2 sensors... i literally just got done with this problem less than a week ago thats why im posting this... unfortunately it cost me a Maf cleaner $100 in spark plugs wasted time and $77 at the mechanic just to find out when we untaped the connected wires it barely had any contact, just tryna save him from the same thing would it hurt if he just rechecked his wiring??? whats the worst that could come from that???
i agree he should check his wiring. I was just clarifying the WOT thing. The op never posted that he could get over that barrier at WOT, which would have been pretty vital info. if he CAN (which you say he can) then he does not have an MAF problem
failure to get over 2.4K rpm is not a 100% maf thing depending on what the CEL code is, it could be an accelerator pedal position sensor (P2138), at WOT the car will go at a max speed of 25mph and wont exceed 2.5K rpms... not his problems however but im just stating this to let others know before jumping to a conclusion about a car staying at a certain rpm that it can be other problems also
