Broken shifter bracket... oh dam...
Old Oct 12, 2009 | 09:17 PM
e-subliminal-2's Avatar
Long story short my shifter bracket broke, the bracket that locks the cable in place near to to the tranny. I ordered one friday, the day it broke, and it should be in tomorrow. I was curious if anyone knows exactly how to change it though, it looks like a few bolts from what I can see from a quick glance,the major clip that holds the cable onto the bracket, and that's it? Anyone got any extra advice?
Old Oct 12, 2009 | 09:34 PM
zero2sixtyZ's Avatar
You embarrass me.
If its the bracket that goes through the undercarriage to the tranny, you need to replace the entire cable assembly. Prepare to lift up the ECU, and route both ends to the correct locations. Much easier with a lift.
Old Oct 13, 2009 | 02:45 AM
Why replace the entire cable assembly? It's just the bracket that snapped. From what I can see, pop out the clip holding the cable down, pop the cable out. Take those 3 (12 or 14mm bolts, breif look) off... and replace it? I'll take pics to clarify. I tried searching but if there's no write up for it, i'll take pics and take an attempt at making one.
Old Oct 13, 2009 | 05:46 AM
Derrick2k2SE's Avatar
I know the one you mean. It bolts to the top of the tranny. It's pretty straight forward but one of the bolts is a b!tch to reach. Having a flex head gear wrench really helps. Other than that the clips pop right off and it's simple.
Old Oct 13, 2009 | 05:57 AM
Rochester's Avatar
Why do you think it broke? Did you drill into the bracket for the STS mod, or are you talking about a different component?
Old Oct 13, 2009 | 09:48 AM
Different component. If you pop your hood, there's a bracket that the clutch line runs against. The line is clipped down onto the bracket. The bracket holds the line is the position where it's known to read "this is nuetral, first, second" etc. It's not where I drilled the hole for the sts, it's before that. It's the only bracket that it connects too and its about 4-6 inches from the fire wall and bolts onto the tranny. How do I know it's broke? Because it's snapped dead clean down the middle and moves wherever it wants lol. Zip tie made me home though. I'll post pics and more than likely do a write up.
Thanks derrick btw for calming my nerves
Old Oct 13, 2009 | 09:57 AM
Farther pic to show Where.
Closer pic to show the break.
Old Oct 13, 2009 | 11:18 AM
Pics up.
Old Oct 13, 2009 | 04:44 PM
You embarrass me.
Wrong bracket / plate I was thinking of. Continue as planned, haha.
Old Oct 13, 2009 | 05:03 PM
haha I figured. Thanks though for the imput, I just wanna make sure this is a short quick replacement. I used another 3 zip ties today and was able to pop it back on to it's original position. It drives normal but i;m trying not to drive it till the bracket comes in.
Old Oct 13, 2009 | 06:09 PM
pmohr's Avatar
No more Maximas...
Quick and easy to replace. Takes 5 or 10 minutes to do, really (I've dropped the 6MT maybe a half dozen times, pulled the shift cable bracket beforehand each time).
Old Oct 13, 2009 | 06:18 PM
tonedef's Avatar
http://forums.maxima.org/6th-generat...ck-my-ban.html
same one??
Old Oct 13, 2009 | 06:50 PM
Yepsame bracket. And wtf?? The dealer told me 70 bucks, andI found it for 40 on an online store.. Let's hope it was the right part. Dealer said "clutch bracket" Said there's only 1 near the tranny. Time will tell. Wow I miss my car, and with the Charlotte meet this saturday, I need it on ASAP
Old Oct 13, 2009 | 06:53 PM
pmohr's Avatar
No more Maximas...
It's not a clutch bracket, it has NOTHING to do with the clutch. It's a shift cable bracket.
34448-AU000, $43.23 each at Courtesy
Old Oct 13, 2009 | 07:17 PM
Excuse my termonology. That part number is the same one I ordered. I'm always confusing the 2. The shift cable bracket is the one I ordered. I ordered it for 43,23 also, but not from courtesy? I called up east charlotte nissan here in Charlotte and they told me it'd be about 70 bucks. Oh well, point being part was ordered. The right part at that. So i'm good for now. Appreciate all the help. Thank Pmohr for the excellent quick answers (as usual).
Old Oct 13, 2009 | 07:37 PM
Old Oct 13, 2009 | 08:23 PM
mist max2000's Avatar
WTH Pmhor... yours like a walking nissan encyclopedia...lol...damn..im convinced you honestly know everything about this car... .. as to the OP .. g/l
Old Oct 13, 2009 | 08:25 PM
hahahahaha, EXACTLY what I said when i pm'd him about this topic last night! I honestly believe he knows EVERYTHING about his, and my gen maxima.
Old Oct 13, 2009 | 08:43 PM
maxboy01AE's Avatar
should be eazy
Old Oct 15, 2009 | 04:28 PM
tonedef's Avatar
I just broke mine again. I have already tig welded the first break, I should have reinforced the whole thing. this time it broke right where it bolts to the trany... wtf.. will post pics when I get the sob off, I hate that damn clip........................
Old Oct 15, 2009 | 08:30 PM
Buy one for the 6th gen Max. They're a little beefier and a direct swap.
Old Oct 16, 2009 | 06:03 AM
tonedef's Avatar
k, thanks... although mine might be the same, I have an 05 Altima SER... Axxtion STS FTL.....
Old Oct 16, 2009 | 07:45 AM
tonedef's Avatar
Old Oct 16, 2009 | 08:43 AM
pimpin02max's Avatar
Agh yes...the beloved linkage bracket...
Broke mine in 3 pieces...
On a side note...it's relatively easy to replace...
Old Oct 16, 2009 | 09:24 PM
We're shifitng too hard=/ ahahaha. I'm gonna definitely slow my shifts down. Well not slow them down but -10 the power for it. Might cost half a second. But the way I look at it speed shifting as fast as I was was only causing me to bark and spin.. Let's try something new. I do NOT wanna run into this again.
Old Oct 16, 2009 | 09:27 PM
That zip tie has been getting me around for 2 days now. (EXTREMELY easy shifting of course). Using it till my new bracket gets in on monday.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
atriuum
Sep 28, 2015 01:19 PM
Violator
Sep 9, 2015 10:14 AM
