How bad is this and anyone else have this problem? Pics inside.
Old Oct 13, 2009 | 10:12 AM
bigfatty's Avatar
Booyah grandma.... BOOYAH
I was changing my alternator today, so I pulled off the plastic cover underneath the AC compressor and got this surprise. The cross beam that supports the frame is rusted something horrible. Large pieces of it are breaking away. The metal warped where the other 'beam", sorry dont know correct word, that comes off it in the middle. I just need help on much of a structure issue is this and how fix if necessary, also how did it happen? Thanks for all the help out there guys.
Old Oct 13, 2009 | 10:33 AM
MadMax07SL's Avatar
If you live near the coast, or they use salt on your roads, that's the cause of that kind of rust most of the time. Perhaps a previous owner lived there if you weren't the origional owner.
As bad as that is, I'd take the alternator back and get a refund. Then, trade in that car quick before your car looks like his:::
Old Oct 13, 2009 | 10:39 AM
hectorc's Avatar
Upper Midwest Wheel Whore
That is more common than you think it is. It happens quite often in the midwest or any areas that receive plenty of snow. I as well as a few other 4th gen members in IL have replaced ours. I heard that Nissan dealerships will replace and weld the lower part for under $200. I'd go that route and get it done.
Old Oct 13, 2009 | 10:52 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
try to get it fixed if you are planning on keeping the car.. if not well fix it as a precaution, who knows what might happen....
Old Oct 13, 2009 | 11:17 AM
e-subliminal-2's Avatar
Is that the CRossmember and frame??? Wow that looks bad. I'd take hectorc's approach even though I didn't know they did that. Me personally, i'd start looking for a new car.
Old Oct 13, 2009 | 11:27 AM
1997MAXZ's Avatar
mine looks similar on my 97 and im getting a bit nervous with winter approaching here in Boston, for 200 I would get it fixed tommorow but i doubt i can find some one to fix it for that price.
Old Oct 13, 2009 | 11:48 AM
bigfatty's Avatar
Thanks for all the help out there, dont stop commenting if you have a thought, but I would be frustrated if this is what ends my run with a Maxima.
I am in Rockford, so not too far at all for a Chicago dealership, anyone one you can recommend for me?
Old Oct 13, 2009 | 11:59 AM
Rochester's Avatar
Yes, it's rusty, and it's kind of scary seeing that crap under your car. But there's probably a lot more structural integrity remaining than you imagine. Steel is pretty strong, even when it's getting rusty.
By all means, have a shop look at it and make recommendations or repairs. But at the same time, don't be afraid to drive your car.
Old Oct 13, 2009 | 01:00 PM
knight_yyz's Avatar
Toolie
It's the lower part of the rad support. I know up here is Canada it's about a 400 dollar job including the part. The old old has to be cut out, and the new welded in. The crossmember is probably fine.
Old Oct 13, 2009 | 11:50 PM
M1RAG3's Avatar
I agree that looks like the lower rad support....
Old Oct 14, 2009 | 06:19 AM
1997MAXZ's Avatar
is this 200$ estimate from the dealer even true/ nation wide due to the fact they feel bad, because I thought about it overnight and if it is true my car will be there today??
Old Oct 14, 2009 | 07:39 AM
hot_wax_tree's Avatar
This is your best answer. Go to a local trustworhty shop and ask them. The guys on here are very knowledge able but you dont know who is a professional and who is just some guy making a guess. Go to a professional shop that you trust and ask them what to do.
I say that is really bad you will need to replace some how.
It looks like the lower rad support to me, and that also makes sense. Get it checked out. Your frame and frame connectors are nothing to me taken lightly.
Jake
Old Oct 14, 2009 | 08:11 AM
rroderiques77's Avatar
Demodded and Forgotten
I would get rid of the car.
Old Oct 14, 2009 | 08:23 AM
ridinwitha35's Avatar
If you're in Rockford, IL, a fellow member has done a few of these for other Midwestern members....see his post here and send him a PM.
Old Oct 14, 2009 | 02:54 PM
raaizin's Avatar
When I change my oil or do maintanence on my car, I do a visual inspection to catch stuff like this before it gets out of hand. A little wire brush and primer goes a long way in preventing rust from spreading.
Old Oct 14, 2009 | 03:31 PM
coldfear13's Avatar
on my old 4th gen, the radiator support rusted through completely where the two bolts are. payed 400 for the part and 100 for the work. my friend had the same thing and payed close to 1k, thats brooklyn prices for ya =[
Old Oct 15, 2009 | 05:24 AM
Professor's Avatar
RUST!
Pretty common, I had my all cleaned up and re welded to fill in the craters and holes, came out nice, I don't know if there all like mine but there is a cast iron beam through the center of that wrapped in the steel, it took over 2 hours for my brother to weld it because of the cast iron that's inside.
Old Oct 16, 2009 | 05:25 AM
djfrestyl's Avatar
Suspension Yoda
It's the lower radiator support for sure. Common issue. You should get it replaced soon. Unfortunately it's not something you can do yourself unless you have or know someone that has a welder.
Old Oct 21, 2009 | 07:34 AM
mandyfig's Avatar
That's really bad looking...hence it pays to inspect your underside once in a while. Probably been happeing for a long time.
Old Oct 21, 2009 | 05:18 PM
williamgd2's Avatar
Find a welding shop that does car frames,I bet you can get it done for under $400.00 But you probably will have to shop around.Or find a fellow org member who can weld.
Old Oct 21, 2009 | 11:31 PM
Mu_036sp's Avatar
Get that Fixed ASAP, If youre selling it. Still Fix it please lol. Screwing someone later will always come back n get ya. id pay how much ever to fix that.
Old Oct 22, 2009 | 01:17 AM
LoveSick's Avatar
That looks bad, but here is the good news.
As mentioned, the rusted area is the lower radiator support, and is VERY easy to replace. The radiator support is installed in such a way that it could be removed and installed in a matter of minutes, excluding bumper removal. The support is welded on by spot welds, and you don't need a bodyshop to do it.
It is far cheaper to replace the entire radiator support than to simply "repair" the rusted area. A brand new radiator support costs around $250 from the dealer. Here is an idea of what it looks like:
Old Oct 22, 2009 | 05:48 AM
djfrestyl's Avatar
Suspension Yoda
^^ That looks like the UPPER rad support, not the lower.
Old Oct 22, 2009 | 07:05 PM
LoveSick's Avatar
The radiator support in the picture contains both the lower and the upper. Nissan does not sell just the lower support. They are connected and are only installed as an assembly.
Old Dec 9, 2009 | 07:34 PM
MyownNismo's Avatar
Future Camaro SS owner
I am getting this looked at sometime this week.
Old Dec 9, 2009 | 09:28 PM
josh662234's Avatar
happened to my 97. The crossmember completely broke off and it was just hanging there. Had a fellow orger here in the boston area do all the work, even ordered the part, for under 450.
Old Dec 10, 2009 | 01:36 AM
4thgenmaxboy's Avatar
A new core support for the 2000-2003 Maxima from Certifit is about $50.00. The fit is really good, and everything seemed to line up good when I used this core support to fix my 03 Maxima front end. Maybe these aftermarket supports will last longer than the O.E. supports. Only time will tell.
Old Dec 10, 2009 | 05:09 AM
Shift_Max's Avatar
Pretty common on maximas especially the older gen models. Like others have stated, fix it even if you plan to sell the car or advise the buyer of it. However it is not that big of a deal to replace it.
Old Dec 10, 2009 | 05:27 AM
.aNiMaL's Avatar
id fix it asap. Driving around with a rusted crossmember like that would scare me. Get an estimate from Nissan first then go from there. Good Luck!
Old Dec 10, 2009 | 06:20 AM
maximal01's Avatar
http://www.autopartswarehouse.com/sk...ts+%26+Mirrors
same problem here in pa ill be replacing the reinforced bumper some time in january
Old Dec 10, 2009 | 06:23 AM
djfrestyl's Avatar
Suspension Yoda
^^ That's not the part we're talking about.
Old Dec 10, 2009 | 06:44 AM
Rochester's Avatar
djfrestyl, he's a Toydarian. Mind tricks don't work on him.
Old Dec 30, 2009 | 04:02 PM
FanaticMadMax's Avatar
I would have it checked by the body shop, i'm sure they strip that rust and prime it and rust proof coating on it, That's the only way, since you live in the NE states, where you get a lot of snow, it's all to common with the rust issues, no matter what kind of cars you get. BTW, how hard is it to replace the alternator?, since I noticed it look like it's hard to access to change the alternator since it's at the bottom end of the engine.
Old Jan 4, 2010 | 11:51 PM
barrylaud's Avatar
BigFatty- Did you ever have this looked at? It could be dangerous driving the car in this condition.
Generally that lower radiator support part can be replaced without the entire core support replaced. You need to consult a local body shop.
Old Jan 5, 2010 | 12:11 AM
MoncefA33's Avatar
I should probably check mine, since my car comes from MN. Although when I was doing headers the core support didn't seem nasty, the crossmember had a little bit of rustage on it though
Old Jan 5, 2010 | 04:41 AM
JonBlz's Avatar
a.k.a. STuNtMAN
I know someone that there's broke off completely and the front was hangin and from him being so low when we went into a gas station that had a little bumpe it did quite some damage under there
Old Jan 5, 2010 | 11:01 AM
kbohip's Avatar
Amazingly enough mine is rust free. Here in Colorado they don't use much salt. Actually they barely even plow the roads at all anymore. You need to get that taken care of asap. That rust will spread very fast now. Personally I'd just buy the new part and make sure to keep an eye on it in the future.
Old Jan 5, 2010 | 02:57 PM
2slow's Avatar
Really? Nissan (dealers) list each component individually.
From https://www.everythingnissan.com/nis...ima-parts.html (not a direct link).
Old Oct 4, 2012 | 06:57 AM
louied9's Avatar
thank god for this forum and its members., Now I am one of them.. I am a gearhead with no fear of removing /replacing any parts on my cars or truck.. I have been suprised after replacing my alt just last week to see the rad support pretty rusted.. it scared the crap out of me , since I just bought this car.. I should hunt down the seller since he did not disclose this to me.. SOB..
the part from nissan seems reasonable about 345$ , minus a local mechanics discount.. looks pretty straight forward, remove all parts up front whack out the old support assy, install new and reassemble.. looks like a 4-6 hour job.. I will be attempting this SOONER than later , but in the meantime I coated it with a POR-15 type of paint to seal it and protect it from further rust.. ill be sure to do a write up when I complete the job with PICS>
Old Oct 4, 2012 | 08:54 AM
andrewmac's Avatar
If you bought the car and didn't notice the radiator support then you didn't look very hard at it. Always have a look underneath before you buy. Also, $345 seems high, you should only need the lower radiator support:
http://www.courtesyparts.com/62530m-...ml?cPath=1956&
That seems a bit better. Also, I hope you have a welder because you aren't supposed to just bolt the thing on. Bolt it on, weld it, seam sealer everywhere. I'm about to go buy a welder and learn how to weld for this specific reason.
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Slamrod
Sep 3, 2015 07:38 PM
FlaMark
25
Aug 28, 2015 10:15 AM
Samedi
Aug 13, 2015 04:05 PM
