A belt in my car just popped, battery light came on but the car still drives...
It's a belt of the left hand side, right below the power steering back up bottle, any idea what this belt is? The car still drives but I don't want to drive the car until I get the belt fixed..
Brake light also came on.
Get a new mechanic.
wouldnt it just be the accesory belt? dont know if its ex or ac for spelling sorry but thats what i call it and the 3rd belt is the the timing chain but chain being the key word but ya don't drive it, it should be relatively easy to replace if you have a second car to do running in
did you just say?
Scott you lose your Alternator belt...And maybe the third belt that your mechanic is telling you is the one from the A/C compressor!!!...You are supposed to have Power Steering Pump Belt, A/C belt, and the Alternator Belt...Last one is the one that you lose because all the lights just turn on in your panel (brake,oil,battery), this is supposed to happen in the panel, just a warning that you lose your Electric Power (Alternator) Anyways, after 100,000 miles you should make a tune-up to your car changing the belts, water pump, timing belt or chain, etc...I hope this info help you!!
Here is a picture from my Cell Phone, you see that the belt is popped.
I bought the Power Steering belt also, hopefully I won't have to change it yet.
http://img158.imageshack.us/i/enginepicture.jpg
Fully charge the battery and drive in the daytime so you don't use any lights. I think the battery will last a considerable amount of time.
Have someone follow you with a battery if you're worried about getting stuck.
Scott, something similar happened to me earlier this week. Expressway driving and suddenly my battery and brake light came on. I googled the reason and it was attributed to the alternator. When I got home I saw that my alternator belt was hanging loose...long story short is that I was able to get about 10 miles out of the car on battery power before it died.
The reason my belt came off was a loose nut on the idle pulley..that had to be replaced and belt reinstall. Everything was good after that. It cost about 1 hour of labor for me..and my mechanics rate is 75 an hour...
hope this helps, but DO NOT drive anymore on your car...get it towed if necessary. If you are in NYC, I can recommend him to you.
Changed my Alt serpentine belt its easy and cleaned connectors and ground at Alt I don't think I need an Alt now she is also back to charging the battery at +13V at the terminals...........
I did turn the radio and a/c off.
2nd belt = Power steering
3rd belt =
Lakersallday24
Jun 16, 2019 01:35 AM
doobadoo
Aug 15, 2015 06:43 PM
Superbform
Aug 11, 2015 08:10 PM
Don't forget the tools to change the battery..
