Cowl drain?
Where does the cowl drain to I need to clean it out as i get rain water dripping on the passenger side carpet after the car has been sitting in heavy rain.
Its not coolant so I know its not the heater core. |
Anybody?
Maybe I should ask "what intake is the best?" to get more responses.:hide: |
LOL...no clue here. It's not in the manual?
lol had the same problem in an old jeep i had.. i never found it..and it started to smell moldy lol...
sorry i dont know... heres a trick.. sit in the car.. and have someone take a hose and 'rain' on your carwith it.. might give you a better idea... g/l |
If you're getting water inside the car it's most likely coming in through the ventilation system. I had a MAJOR problem in my Camry, (OK not a Maxima) and it was the seal around the air intake under the cowl. The water travelled through all the vent conduits so all 4 areas of the floor were completely soaked.
Start by removing the cowl (you probably have to remove the wiper arms to get it off) and stick a hose into the drains, they're at each corner, to see if they are clear. You may have to poke a piece of wire into them to clear them out if they're clogged. If they're not clogged then look around the air intake where fresh air gets pulled in. That's where my Camry's problem was. |
I'm also considering that it may be the condensation from the AC...but I dont recall it happening unless its raining. That may be because the humidity is higher when its raining causing more condensation....
The spray hose is a good test. Get somebody to hose the car front and you sit and find where it is coming from. I have to do this on my rear, there's a leak going into the trunk.
© 2024 MH Sub I, LLC dba Internet Brands
