A newbie with a ton of ?
Great to be a part of this Maxima Forum. Am a member of other car forums as well.
Newbie asking for guidance. I have read the FAQ’s and I think I am ready to enjoy my 1st Nissan car, 2000 Maxima GLE, Gray. Currently use a 98 Acura 3.2TL 88K as daily ride.
Purchased a 163K miles 2000 Maxima, and am itching to perform procedures to get it up to good running condition, making sure whatever the previous owner screwed up on, I can correct.
Thanks to this forum I have downloaded the owner’s manual and have done some research on the fluids-maintenance items required. These are the things I want to do and have listed quantities required and would really appreciate your help in correction-suggestion-tips:
Touch Up paint Where can I find the GRAY color ID? Or else, anybody used a near match on the Duplicolor touch up paint? KV3 Gray Lustre OK.
Oil Change 5W30 Syn 4.25 Quarts Done.
Tranny Drain-Fill Dexron III/Mercon ??? Quarts 4 QTS OK.
Power Steering Dexron III/Mercon Suck up and refill. To be done still
Coolant Change ??? 8 1/8 Quarts (Where is the engine drain bolt?) To be done still
Brake Fluid DOT 3 Bleed To be done still
Brake Rotor/Pads Fr Checked the pads, still OK, need to turn the rotors, I have pulsing. Change it next time. Done. Rotors turned, new pads.
Air Filter Done, Purolator….the old one was NASTY.
Wiper Blades Done. TRICO OEM fit replacements. Freeking previous owner scratched the glass with OLD wipers…how to remove scratches? Polishing?
Headlamp Polished with Brasso. Some of the haze is inside the lamp.
Fog Lamps Polished with Brasso and waxed it..
Being 163K, what are the things that I need to be checking on/doing to make sure the car will provide reliable service.
Yesterday spent hours just cleaning it up. It is now in decent condition. I like the spunk of the Maxima, now I feel my TL is like a slow middle aged person!
Thanks in advance and looking forward to be a contributing member!
mandyfig
mandyfig
mandyfig
mandyfig
Ok now, how's that? Need input guys...I am raring to go! The need to work on the MAX is so great...but will not do it without proper guidance. As they say, measure twice and cut once....!!
You can use any version and it will make no difference for the rest of the users, as long as you don't change the font color.
You might want to download a copy of the Factory Sevice Manual (FSM) too. It comes very handy. Check the diagram below for the location of the color code (taken from the FSM):
Thanks will get a copy of the FSM. Where is this plate-note located?
Try the link below. It has all the individual sections of the FSM and it looks like is it live:
http://www.nicoclub.com/FSM/maxima/2000/
here's a working link for the FSM
Flushing with a machine is definatly not recomended but you can flush the trans by detaching the line going into the radiator and using the trans pump to flush the fluid a few quarts at a time. Here is a link to Jime's how to do this procedure. 4qt to drain/refill and 10qt the flush.
http://jimesmaxima.com/AutoTransFluidChange.html
these should keep you busy for quite some time... hope you dont mind some reading..
http://forums.maxima.org/5th-generat...n-how-diy.html
http://forums.maxima.org/5th-generat...on-issues.html
http://forums.maxima.org/5th-generat...fications.html
Thank you very much!
I have downloaded the FSM finally, lots to read!
Thanks again.
Thanks I have gone through every one of them. Need to read slowly and pick up key points. A ton of information...short period of time....
I am just a frustrated mechanic...always itching to repair, modify, improve things in the car....keeps me busy and adds to exercise. But costs money, too.
Patience is a virtue, I remind myself all the time. Thanks for your help.
Are Europe and US identical?
Edit: Never mind I found the answer. Download from the folder that says 2000.5, not the 2000. That european Maxima QX looks more like an Infiniti I30 to me.
Rims will be painted same color. Have 2 which are faded and dull. Might as well paint the 4 of them to even out the color. For now they look fine, but eventually I want to paint them all. Or else I am looking to get G35 rims....that's a better option!
