help please.
Old Oct 26, 2009 | 04:46 PM
johny walker's Avatar
help please.
ok i put my cai on my 2002 max today and went up the stret to get gas in my car and when i got back in my car everything went dead. its like there is no key in my ignision. had to walk home from gas station and am here now. i need help. is it security or wht. tried jumpin it and still nothing.
Old Oct 26, 2009 | 04:53 PM
Feldman's Avatar
did you check your fuses?
My initial guess would be you lost connection with your ground but it could be a handful of things
Old Oct 26, 2009 | 04:54 PM
20Max03's Avatar
Mass Air flow sensor possibly? did you damage it during the install
Old Oct 26, 2009 | 04:58 PM
VQP0WER's Avatar
If zero power, then you must have damaged the battery cables while installing your CAI.
Old Oct 26, 2009 | 05:06 PM
ok the battery cables were not cut or dameged in the install. and the maf is not broken.i did that to my 95 and had to replace the damn thing. it is not a running problem it has to be some security thing. the car started up fine and everything right when the install was complete. the car has power but does not show any dash lights when keys r turned and windows will not roll up but if holding the doors locked with keys windows will roll up.
Old Oct 26, 2009 | 05:54 PM
please someone help.
Old Oct 26, 2009 | 06:06 PM
Feldman's Avatar
do you get power to your accessories? (lights, radio etc)
I would start by removing the cables from your battery cleaning the terminals and putting them back on. I had a similar loss of power and it happened to be the connection at my negative terminal. The cable was attached but no connection was being made
Old Oct 26, 2009 | 06:15 PM
i get power to my lights but no other accesories.
Old Oct 26, 2009 | 06:25 PM
Feldman's Avatar
Have you checked any fuses? sounds like you are getting power to the fuse box in the engine compartment but not to the one in the cabin. I am guessing there is a big fuse in your engine compartment that is blown.
Old Oct 26, 2009 | 06:53 PM
e-subliminal-2's Avatar
Same thing happened to mine, Did you disconnext your terminals when putting the intake on? Even if you didn't. My terminal for my battery was BARELY on. It looked on but was loose. I received power to my gauges but my car wouldn't start. Tighten up both terminals. SHouldn't be any play in them.
Hopefully that's it. I don't see why anything else should have went bad, it's just an intake swap..gl
Old Oct 26, 2009 | 07:17 PM
Nelsito65's Avatar
I don't remember which items are controlled by the big fuse that sits right next to the negative battery terminal, but you might want to check that one too.
Old Oct 26, 2009 | 07:56 PM
have checked all fuses and still nothing. all my accesories are dead but my lights will turn on manualy but not by the auto setting. could this be a ignition problem. also with the loose battery terminals thing the lights would not turn on. right
Excalibur23
Oct 13, 2015 04:33 PM
mpbclutch33
Sep 1, 2015 09:24 AM
