Rear door (driver side) is locked from inside and outside .. please help
Old Nov 4, 2009 | 12:21 PM
amansour14's Avatar
I have Nissan Maxima 2002 SE
My rear driver side door is locked and I can not open the door from inside and outside ... I can not open it from inside because the child lock is on but I do not know why I can not open it from outside ... Maybe the exterior door handle is bad ...
the center lock is working fine..
I do not know how to remove the inside door panel .. because it is locked
Is there a way to remove the exterior door handle without removing the interior door panel?
please help ... anyone has the same problem before ?
Old Nov 4, 2009 | 01:03 PM
Feldman's Avatar
I think you are going to have to take the door panel off, i bet you you can get the door panel off with the door closed. You might have to take your lower seat cushion off to make some room though
Old Nov 4, 2009 | 03:00 PM
amansour14's Avatar
I did not try to take the lower seat cushion, I think this will help ..
I will try it and let you know
Old Nov 4, 2009 | 07:26 PM
madmax17's Avatar
you definitely need to take the lower seat cushion out. There is a thing that you need to pull on. I had a similar problem and I had to take it my car to the nissan dealer. They said there was a little rust in there. So they sanded it and used some lube. They ended up doing the other door too. It ended costing around $300. Definitly try to fix it your self first.
Old Nov 5, 2009 | 05:03 AM
Professor's Avatar
Sucky, i have the same prob, i havent opened that door in at least a year, i had the panel off and I still cant get it open, i dont know what else to do. i want to avoid the dealer.
Old Nov 5, 2009 | 05:52 AM
gotendbz1's Avatar
use the other door.
Old Nov 5, 2009 | 07:46 AM
Professor's Avatar
Originally Posted by gotendbz1
use the other door.
ha ha ha i kill me
rtirbany
Sep 8, 2015 11:46 AM
Stelianos
Aug 19, 2015 02:07 PM
shaunkey1
Aug 18, 2015 10:09 PM
