Replacing control arm
Old Dec 9, 2009 | 11:55 AM
ohitzme's Avatar
So i bent my lower control arm on a 2000 nissan maxima. Was wondering how hard is it to replace and if anybody had a how-to?
Also what tools are neccesary for the job.
Old Dec 9, 2009 | 12:32 PM
OOmaxSE's Avatar
It's doable in your driveway with jack stands. I believe it's easier to allow both front wheels to be raised so the sway bar links have less tension when removing them. There are a bunch of 22mm bolts that need to be removed along with the ball joint nut.
How'd you bend your LCA? Are you sure it's out of whack?
Old Dec 9, 2009 | 02:57 PM
Professor's Avatar
Not hard at all, i just did mine.
Balljoint bolt may be the hardest to remove, mine took me 2 hours and a air hammer to remove.
Old Dec 9, 2009 | 03:01 PM
ohitzme's Avatar
I ran into a curb took it to a shop and they showed me how bent it was. Also the steering wheel is crooked.
Alright cool thanks!
Old Dec 10, 2009 | 03:53 PM
ohitzme's Avatar
Update: New lower control arm is put on.
Went to get it aligned and am still at 2.61 degrees the shop told me to buy and install a new strut and on the way out was stopped by a guy inside that was a customer there. He said he is an insurance adjuster and odds are i bent my engine cradle, and i should think about calling my insurance company.
So what do you guys suggest new strut or to call insurance?
Old Dec 15, 2009 | 10:00 AM
timmyg1's Avatar
Not hard. You can get the control arm with bushings and Ball joint. I would look for a control arm with a push in Ball Joint instead of a bolt on. Make sure you have the car securely jacked up. You will probably have to compress the springs a bit. Be careful getting the Ball joint bolt off, use a good wrench, they are pretty soft metal. Lastly make sure you have a breaker Bar because those nuts are really on there. And try to stay out from under the car when putting that much pressure on the wrench to be safe. Put it back on with a large Tourque Wrench, you do not want that part coming off
Old Feb 22, 2010 | 07:27 AM
jwsmith's Avatar
lower control arm replacement
While sliding down the icy road I slammed my right front tire against the curb. The lower control arm is bent and the sway bar link broke.
I have all the tools to replace these parts. I replaced the discs, pads and strut assemblies last summer so I know the bascis of the front suspension.
These are the FSM instructions on replacing the lower control arm:
  • Remove wheel bearing lock nut
  • Remove tie rod ball joint
  • Remove strut assembly fixing nuts and bolts from knuckle
  • Separate drive shaft from knuckle by slightly tapping the drive shaft end
  • Separate lower ball joint stud from knuckle with suitable tool.
  • Remove lower control arm fixing bolts
  • Remove lower control arm and lower ball joint
  • During installation final tightening must be carried out at curb weight with tires on the ground
Are there any other tips I need to successfully replace this bent lower control arm? Do I need that suitable tool to seperate the lower ball joint from the knuckle?
Please also recommend a lower control arm set that comes with the ball joint and bushings and an online site to buy it from. I'll probably buy the moog sway bar link.
I'll be flooding these rusted bolts with PB blaster and use a blow torch if nessecary. I'll apply anti-seize to those high torqued nuts & bolts.
Old Feb 22, 2010 | 06:04 PM
ridinwitha35's Avatar
Regarding the "suitable tool":
I think they're most likely talking about a pickle fork that you wedge between the control arm & knuckle, and hammer a bit til they separate (that is, after you get the nut off). Personally, getting the nut off was the hard part; don't recall having to do anything special to separate the knuckle/ball joint - or maybe mine was that jacked up/loose.
Old Feb 22, 2010 | 06:08 PM
bigpopaj369's Avatar
this threads 2 months old im sure he did something about it already
Old Feb 22, 2010 | 06:14 PM
Not the post above mine.
Old Feb 22, 2010 | 07:45 PM
jwsmith's Avatar
Can I break loose (not remove) the wheel locknut before I raise the car? It requires so much torque it seems impossible to break loose with the wheels raised. I'll try using my 1/2" breaker bar with a craftsman 23mm socket.
I just ordered a mevotech lower control arm and a moog sway bar link. They both include the bushings. I'll stop by at autozone and ask them about that tool to seperate the knuckle and lower ball joint.
Thanks for your help ridinwitha35
Matt93SE
May 24, 2019 02:58 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
