Please help verify that these parts fit.
Old Jan 5, 2010 | 04:40 PM
jl7288's Avatar
How are you guys? I've posting a bit asking for help regarding SES codes P0138 and P0158 on my 2k2 SE. THis is going to be my third time buying sensors for these problems and hopefully my last. I checked through amazon.com and it said that these parts should fit.
First code: P0138-Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1). WIll Bosch Part number 15727 work?
Second code-P0158-Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2. Will Bosch Part number 15726 work?
Thanks for all the help guys.
Old Jan 5, 2010 | 06:50 PM
johnnyd2k2's Avatar
Those should work but you're better off spending the extra cash for exact fit O2s you're gonna have to wire the conecters yourself with those paticular ones here IIRC they should run around $120 each
Here are some links
http://www.courtesyparts.com/maxima-...7699_9249.html
http://www.autozone.com/autozone/cat...ll&totalPages=[I@d915cc&currentPage=1&vehicleNValue=&navValue=161 00117&parentId=61-0&fromString=&fromWhere=null&filterByKeyWord=&cate goryNValue=&categoryDisplayName=Exhaust&_requestid =2054470
Old Jan 5, 2010 | 07:32 PM
2kmax865's Avatar
According to the P0138 & P0158 codes both sensors are down stream sensors, so you would use 2 15727 sensors. I would use the direct replacements, P0138 code calls for 15225 white cable color & P0158 calls for 15224 red cable color.
derekinthez
Nov 13, 2022 04:00 PM
MR2 T'd
Jul 9, 2021 05:06 AM
Mar 12, 2020 12:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
videomano
Sep 8, 2015 03:28 PM
