Anyone ever use UpRev Engine Management?
Anyone ever use this tuning service on thier max? Is this exclusivly for the 350z only. Looks like some serious power gains are possible with this. Discuss.
http://www.uprev.com/products.php
If you want a real good tuning solution, you still have a few different options.
You will need a wideband O2 sensor to monitor your AFR regardless.
- V/SAFC -- Basic tuning, alters MAF signal to control Air/Fuel Ratio -- easy to hook up, cheap, easy to dial in. Self tuned.
- TurboXS UTEC -- Full piggyback with on board datalogging, rev limiter control, injector control, ignition control, knock control -- very advanced and awesome control, most expensive/hardest to install, self tuned.
- e-Manage Blue -- injector/MAF control -- sorta involved install, cheap, self tuned.
- Technosquare -- ECU Reflash, remapped AFR, ignition timing, rev limiter, and variable cam timing maps -- no tuning necessary, somewhat expensive.
Do a little more searching, quite a few 5.5 guys are running UTEC so you'll have some good info at your fingertips.
The same underlying principles in tuning an N/A car are apparent regardless of what you use to tune.
I want someone to make a piggyback that has an input for a wideband and will use the wideband info to maintain the AFR on the fly. Wouldn't that be nice LOL
PS; e-Manage Ultimate does that. Autotune + AFR harness + wideband serial output = tunage.
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Osiris can be used on 04+ cars. I have a mind to find a non optioned 1995 4th gen and do a full 3.5 6th gen ECU swap + 6 speed with revup heads and osiris tune.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
CAN-Toronto FS: E-Manage Ultimate and patch cable
knight_yyz
Oct 24, 2015 08:05 AM
