Engine Oil Change Question
Old Jan 18, 2010 | 06:51 PM
showstoppa01's Avatar
HEy Guys i Got my 03 Max from an auction July 2009 with 101,700 miles. I did an oil change in October 09 with Castrol High Mileage. I'm due for a change this month. Can i Change to Mobil 1 synthetic? Or stick to the high mileage Oil?? And would there be any problems in the engine and performance if I change to Mobil 1 synthetic because i used Catrol High Mileage previously?
Old Jan 18, 2010 | 07:41 PM
jasonmax's Avatar
I dont see why you cant.
Old Jan 18, 2010 | 09:04 PM
The6spdMax's Avatar
Does the engine consume oil at all? If not, then I would stick with Castrol High Mileage.
Old Jan 19, 2010 | 05:07 AM
mandyfig's Avatar
Are you using 3 months as basis for changing? Go by mileage. 5K on dino oil, 8K for synthetic oil. Unless you want to dump money. Be friendly with the environment...
Old Jan 19, 2010 | 06:16 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Mobil! and you are good to go........
Old Jan 19, 2010 | 06:26 AM
mandyfig's Avatar
Switch to Synthetic.
Old Jan 19, 2010 | 07:49 AM
Thanks Guys I appreciate it. I really havent notice any Oil burning. But i will check on that. Any symptoms of Oil Burning i Should notice?
Old Jan 19, 2010 | 08:04 AM
Lontar1's Avatar
Pull the dipstick out and if it is low, there you go.
Old Jan 19, 2010 | 08:54 AM
914Max914's Avatar
i run Mobil 1 full synthetic never had a problem with it.. nd i have a slight oil burning problem
Old Jan 19, 2010 | 09:08 AM
mandyfig's Avatar
I am flushing my Max, using dino oil for 2 short oil changes and then I switch to QS Ultimate Synthetic.
Old Jan 19, 2010 | 11:27 AM
demasi1515's Avatar
You shouldn't have an issue switching from High Mileage oil to Synthetic, but they say it's not good to switch back.
I like the Castrol Syntec 10w30 Synthetic, with the K&N Filter. I change mine every 4500 to 5000 miles (Probably throwing money away on it, but it makes me feel better about myself ).
Old Jan 19, 2010 | 11:55 AM
mandyfig's Avatar
That's what counts!!!
Old Jan 19, 2010 | 12:37 PM
LowVybez2DeMax's Avatar
mobil1 is the way to go
Old Jan 19, 2010 | 12:59 PM
Rood's Avatar
synthetic.
Old Jan 19, 2010 | 02:38 PM
williamgd2's Avatar
I thought you might have a oil leaking problem switching to synthetic with high miles.That is what I have read.
Old Jan 19, 2010 | 04:03 PM
boost4age's Avatar
Yeah i my engine loves that QS
Old Jan 19, 2010 | 04:41 PM
VQHP's Avatar
Sunglasses required..
ROYAL PURPLE 5-30W FTW!!
Old Jan 19, 2010 | 08:45 PM
geenowalker's Avatar
just finished my 47th oil change with M1 Synth 10W30....and just passed 200K last week. Incidently, I get the same 20 mpg that I got the day i drove it off the lot. Love my max.
Old Jan 20, 2010 | 02:04 PM
a33i30's Avatar
Old Jan 20, 2010 | 06:01 PM
Night_raiders's Avatar
typical changing from a high mileage to a full synthetic is fine. but it is not recommended to down grade as in going from a full syn to a conventional oil.
Old Jan 20, 2010 | 06:47 PM
beefy23b/97's Avatar
AMSOIL
25k or one year between changes which ever comes first.
Old Jan 20, 2010 | 11:44 PM
BronxSleeperMax187's Avatar
Old Jan 24, 2010 | 08:47 PM
soto2635's Avatar
depends on what kind of driving you do, if u do alot of stop and go driving, better of with the synthetic oil, if not it doesnt hurt to use conventional oil but i personal use the synthetic b/c i dont have to change the oil as often and its better over all. just my 2 cents
Old Jan 25, 2010 | 09:35 AM
mandyfig's Avatar
Synthetic is the wave of the future. Either follow a regimen of 8~10K mile change or look at your oil, if it is getting dark, time to change. You will see it change color around 8K. That means it has picking up dirt.
But yes, switch over to SYN.
Old Jan 25, 2010 | 12:17 PM
nismonegro26's Avatar
I was wondering which weight would be better? 5-30w that is recommended or 10-30w? I'm just now getting to 69000 miles
Old Jan 25, 2010 | 12:33 PM
Gillikanoosis's Avatar
Based on my experience, the only problem you will have is the cleaning agents in synthetics removing build-up that has help seal potential leaks. Some cars experience temporary oil leakage due to this removal of the natural "helping" build-up. Eventually, as long as your seals are adequete, the synthetic will re-invigorate the seals and you're good to go. This is an average experience.
Worst case: switching will reveal seal problems which will need attention. Best case: you'll experience no noticable affects.
BTW: Who Dat?!?! Geaux Saints!
Old Jan 25, 2010 | 01:30 PM
spock's Avatar
I switched to synthetic @ 67k and have done 2 oil changes since. No leaks, no problems. I stick to the factory maintenance intervals just because I like clean oil in the crankcase and the filters are so damned small. I always look for sales and stock up on Castrol Syntec.
Old Jan 25, 2010 | 02:04 PM
Colonel's Avatar
Old Fuddy Duddy
Say WHAT? Synthetic does not do anything to the seals. In fact, synthetic does not cause seal sweal like most conventional oils. It will not mysteriously make a leak go away.
As you correctly noted, it will clean away the crap that might have been hiding a leak but it wont make it go away over time. If switch between conventional oil and synthetic causes a leak, it means that you need to repair something or live with the leak.
Old Jan 25, 2010 | 06:54 PM
It is no mystery.
In some cases, switching to
synthetic oil will clean sludge away that could reveal seal deficiencies.
Due to the molecular structure of synthetics and their bonding/adhering qualities, these "leaks" can be reduced because of the nature of the oil.
Synthetic oils are not a cure and as I stated before, these "leaks" more than likely point to a problem in need of attention.
Old Jan 25, 2010 | 07:02 PM
Colonel's Avatar
Old Fuddy Duddy
It is no mystery.
That I will buy.
No way. I need a paper or a url or something that backs that up. I have never seen that stated and I spend a heck of a lot of time on BITOG.
Old Jan 26, 2010 | 05:15 AM
knight_yyz's Avatar
Toolie
german castrol 0w30 for the win.
Old Jan 26, 2010 | 06:11 AM
n3985's Avatar
大陆弟弟
Trying to find it FTL.
For all the Royal Purple leg humpers, note it shears easily in as little as 5000 miles seen in oil tests.
You are better off using Pennzoil Platinum 5W-30 or Mobil 5W-40 1 synthetic since VQs love heavier weight oil. German Castrol is heavy enough to almost be classified as a 40 weight.
Otherwise GC 0W-30 >*, followed by Amsoil.
Old Jan 26, 2010 | 10:45 AM
ceno22's Avatar
i work in an oil change shop (no name ffor legal reasons), switching oils at that mileage CAN CAUSE LEAKS. high mileage oils and synthetics have additives which lubricate seals however a sudden change can damage them, ie. changing at high mileage.
if u regularly change your oil (every 5k) then the change shouldnt effect it. and syn oil doesnt restore seals.
Old Jan 26, 2010 | 11:08 AM
Colonel's Avatar
Old Fuddy Duddy
Yes, if you switch to syn it can cause leaks by revealing a problem with seal that has been covered up by conventional oil. The syn itself IS NOT causing the leak nor will it make the leak go away.
High mileage oils have additives to replicate the seal swealling characteristics that conventional can cause. Again; Its a STOP GAP measure. If you have a leak and use syn it means YOU HAVE A PROBLEM and need to fix it.
You will not see catastrophic failure of a motor due to switching of motor oils unless the engine was never taken care of.
Old Jan 26, 2010 | 11:30 AM
williamgd2's Avatar
But what I stated way above switching can cause a leak that may not have developed if you did not make the switch to synthetic.
Old Jan 26, 2010 | 11:54 AM
Colonel's Avatar
Old Fuddy Duddy
And that would be a failure of a seal that would go sometime. Find it and fix it or put your head in the sand and hope one doesnt exist.
Its not causing a leak. Its revealing a leak, and existing problem that is being covered up by poor maint or inferior parts. Synthetic does not cause leaks.
Old Jan 26, 2010 | 01:31 PM
williamgd2's Avatar
Thats bull it very likly will never leak if you didn"t make the switch.Do a search it should not be hard to find the info. I have nothing against synthetic I think it is great stuff but it is pretty well know by people in the business that it can cause leaking in high milage cars that would not have leaked without the switch.
Old Jan 26, 2010 | 01:47 PM
williamgd2's Avatar
http://forums.gmhightechperformance....eak/index.html Here is one unbiased example but if you read what Moble or the other oil dealer's say you are not getting the truth, They want to sell you oil.There are a ton more but don't listen to what the oil co's say about the oil they want to sell you.
Old Jan 26, 2010 | 03:20 PM
FRZ251's Avatar
Eneos 0w-50. Enough said, this is a real synthetic oil. Engine runs noticeably quieter. Its insane.
Old Jan 26, 2010 | 03:24 PM
knight_yyz's Avatar
Toolie
auto zone, wally's world, I never have a problem finding it in Canada or the US.
