Start sound - getting worse
Old Jan 24, 2010 | 12:55 PM
JonMcJunkin's Avatar
Since late summer (around 80 degrees Fahrenheit) the car has been starting odd. When you turn the key, it turns on normally, but it gets really loud and sometime the RPMs rise above 2000. This may not be abnormal, but it doesn't sound like a car should. Multiple people have asked why the car makes the noise. It would only make this noise when it was not warmed up (fall and winter).
However, now, even after driving the car from 2 minutes, 20 minutes, or two hours, the car still makes the noise every time you turn it on. And sometimes, it seems like the car may be a little more hesitant to start because the RPM gauge will raise, drop, raise higher, drop lower, then be at around 700rpms.
This definitely is not normal, what is making this noise?
http://www.youtube.com/watch?v=ezgfQig0cXg
Old Jan 24, 2010 | 01:05 PM
Mr. Brett's Avatar
I don't have speakers here on my work computer, but if it's a loud clattering, that's the timing sprocket. It's normal on older VQ's.
Mine does it quite a bit as well, and oftentimes, if I leave it sitting for about 5-10 minutes after I've driven, it'll do it again when I start as a result of the oil draining back into the pan.
Check your oil level, and also give your car 10 seconds or so when you start it to let the oil work its way into the sprocket.
Old Jan 24, 2010 | 01:20 PM
I gave youtube a search and a VQ35 from a sixth gen Maxima came up that had a timing chain tensioner issue, and I heard the 'clattering' sound you were talking about. This is not what it sounds like, however. It's a loud, almost high pitched noise that sounds like it's 'catching' onto something. I don't really know how to describe it, almost as if you're car is high in RPMs, won't shift, and has a constant sound at that RPM, then it finally shifts is the only way I can think of on how to describe it.
Old Jan 24, 2010 | 01:28 PM
Mr. Brett's Avatar
I'll give the video a listen when I get home. I don't even have a set of earphones to use here.
Old Jan 24, 2010 | 02:08 PM
spock's Avatar
Almost sounds like your starter is staying engauged after the engine starts.
Old Jan 24, 2010 | 02:12 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Or possibly a malfunction in the transphasic inducer on the primary plasma manifold... What do you think, spock?
Old Jan 24, 2010 | 02:47 PM
jasonmax's Avatar
starter solenoid is bad? the starter gear is catching when you let go the key.
Old Jan 24, 2010 | 03:32 PM
spock's Avatar
Don't make me lock in the Foton Torpedoes on you!
Old Jan 24, 2010 | 04:22 PM
5spd2000SE's Avatar
Starter is sticking. Mine was doing the same thing. I replaced the starter and I've never heard it again.
Old Jan 24, 2010 | 04:51 PM
sascuderi's Avatar
I agree, sounds like the starter. Had to replace mine just recently on my 2000 I30 with 71K miles. At first it would pause during the start and then it was making a grinding noise. Like yours, but not as long in duration. All has been normal since the new starter went in.
Old Jan 24, 2010 | 07:40 PM
Thanks all, that is actually the way I described it to everyone who asked. "I think the starter is sticking or catching onto something." Is the starter a do it yourself project or a bring it into the shop?
Old Jan 24, 2010 | 07:56 PM
Scottwax's Avatar
That's Mr. Detail to you
I agree with the others, sounds like the bendix gear on the starter isn't pulling back in quickly enough.
Old Jan 24, 2010 | 08:04 PM
Thanks for your input.
Off topic, but the black tails really look good on your car. And have you gotten a chance to get your car fixed since it was backed into?
Old Sep 9, 2010 | 06:04 PM
Parthur's Avatar
Has anyone done this? Changed the starter? I think I am having this problem, only happens the second that I release the key after starting..... How hard is to do? any instructions in here. ( Haven't found anything)
Old Sep 9, 2010 | 07:15 PM
2slow's Avatar
For everything:
http://www.nicoclub.com/FSM/
Old Sep 10, 2010 | 01:17 PM
Parthur's Avatar
For everything:http://www.nicoclub.com/FSM.
Thank you Sr.
97_GXE
Sep 15, 2015 06:47 AM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
