Max overheating, need help asap
Old Jan 24, 2010 | 05:16 PM
ghost's Avatar
So I just replaced my Radiator with a Loyyo brand that I got from a local place here in los angeles, Thermalstat with new gasket & both top & bottom hoses for rad I got at the dealer cause it's a couple blocks from my work & didn't have time to wait for shipping cause my old had blown.
I spent yesterday flushing car because I had the toyota red coolant & wanted to make sure it was all out because I'm switching back to nissan green. I did my last flush this morning & water was clear, I also blew into the top block intake so that all the water would come out & pour new coolant into it so that it would have some when I start the car.
I started car and waited till it warmed up and checked for any leakage & did not see any, I then drove car keeping an eye on gauge temp & it stayed at 3rd line (normal) & after 6 blocks into it I notice temp started rising rapidly so I pulled over & let cooled, I also checked for leakage & did not see any.
After I let car cooled for half hour I drove back to my house and saw temp stayed at normal & when I got home I got out to check for leakage and saw none & I notice that the fan was on so everything looked fine until I went to shut off car I saw temp climbing back up.
This has me puzzle because I make sure I put everything back that way it was & I could feel both hoses hot so I know coolant is circulating, so what can it be? bad thermalstat? any ideas?
Old Jan 24, 2010 | 05:23 PM
Scottwax's Avatar
That's Mr. Detail to you
You've probably still got air in the system.
Old Jan 24, 2010 | 05:36 PM
ghost's Avatar
Stupid of me I forgot to check the rad for fluid levels, will check tomorrow morning, I just started freekin out. Thanks for quick response.
Old Jan 24, 2010 | 06:42 PM
hotstartup's Avatar
bleed more
Old Jan 24, 2010 | 08:01 PM
Nelsito65's Avatar
Your car is showing the exact same symptons I had with mine. I also replaced radiator and thermostat along with flushing my cooling system a couple of times (the old coolant was red, not because of the color of the coolant but because of corrosion sediment). In addition to that, I bled the system twice, revving the car for as long as 30 minutes as it was parked on an incline and with the front jacked up as high as I could, so that the radiator opening is above the heater core level. In the end I ended up replacing the water pump which was the source of the problem to begin with; the fins were completely gone.
I sure hope you issue is just the need for purging the air out of the system.
Old Jan 25, 2010 | 01:06 PM
ghost's Avatar
Hey Scottwax you were right, added about 1/4 of gallon this morning and that's all it was. I still heard the bubbly noises as I drove it for the first two miles on my way to work and notice that the reservoir had gone down a bit when I got to work, also the temp gauge remained steady at regular line/temp. Will check for leaks again after work & refill reservoir before I take off.
One last question, since I put the nissan coolant and it's already 50/50 and I know block had some water in there (I estimate about a quart) cause I didn't unbolt the block screws is it wise to drain radiator once or twice and refill with coolant so it can become close to 50/50?
Old Jan 25, 2010 | 02:06 PM
homeyclaus's Avatar
You can check the coolant's specific gravity to see what the freezing and boiling points are, and make that decision then. I prefer non-pre-mixed coolants for this reason. Ethylene glycol is the same the world over, and as long as the additives get along with aluminum parts (and already-present additives) you're good to go.
In the "I am new but have questions" thread a few pages back I posted this on clearing out the air in the cooling system/filling it with minimal hassle. Works on most vehicles this way, except for Dodge Darts, K-cars with US engines, and, well, anything else with an asinine cooling system with high spots in there that block things.
The usual warnings about needing to know what you're doing, keeping objects and body parts away from moving engine parts, and I am not liable if you hurt yourself and/or your puppy dies apply:
1. Open radiator. Fill with coolant.
2. Start car, turn heat to maximum, top up coolant.
3. Let engine warm until thermostat opens (top rad hose will warm up suddenly) and top up again.
4. Rev engine a bit higher, top up, close rad cap.
5. Fill overflow tank half way.
6. Put jug of coolant and a jug of water in the trunk.
7. Go for a drive. Run it normally for some time - don't rev the **** out of it, race people on route 29, or whatever.
8. Have lunch, letting engine cool.
9. Check coolant level in the rad again.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
