help, problem idling
Old Feb 6, 2010 | 06:09 AM
NissanTun3r's Avatar
Hey a friend if mine has an 06 nissan murano and has a problem idling. It's fine when he is driving around, but when he for instance stops at a light or stop sign then the rpms fluctuate, drop, and the engine cuts off. Since this fwd vq is the same as our maxima I figure the gurus here could help me out?
Old Feb 6, 2010 | 06:20 AM
denny_1986's Avatar
his IACV is busted...is the CEL on?
when the IACV on my 01 broke, it took the ECU with it
a very serious design flaw!
Old Feb 6, 2010 | 06:25 AM
I was thinking it was the iacv too, is that something I can DIY?
Old Feb 6, 2010 | 06:30 PM
Nexus67's Avatar
"his IACV is busted...is the CEL on?
a very serious design flaw! "
Also: Check SEL codes (if any) b/c it could be ignition coil failure
Old Feb 6, 2010 | 07:11 PM
gamiller31's Avatar
You can change the IACV, but will require patience. The IACV can cause the ECU to short out, but not in all cases. Take care of the IACV immediately, befeore(hopefully) it can affect the ECU. While doing this, address any other issues(PCV,MAF,EGR,etc...).
Old Feb 6, 2010 | 07:29 PM
P. Samson's Avatar
It hasn't got an IACV......it's a VQ35 with fly by wire throttle. Probably best to just start troubleshooting by getting it hooked up to a scantool such as a Consult ll at a dealer.
Old Feb 6, 2010 | 08:00 PM
jasonmax's Avatar
its a 3.5 so its fly by wire
Id say its the o2 sensors
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
