sunroof controls
Old Feb 20, 2010 | 08:13 PM
kiyakerz's Avatar
sunroof controls
I'm at a bit of a loss here for how to operating the sunroof. I've owned two other maximas, both of them were third gens. On those you simply held down the button until it was at the position you want.
On the 5th gen I have a slider switch that doesn't seem to do anything and then a button that makes the sun roof move like 3 inches and it stops. I then have to release and hold it down again for like another 2 or three inches. Repeating this process until it is all the way open. Did I miss something or is my sunroof just broken?
Old Feb 20, 2010 | 08:27 PM
Ghost_54's Avatar
I'll assume that sunroof operates the same as the 5.5 gen that I have, the first switch is for full auto open. (yours sounds like the track may need some greasing as it should not stop part way) the other switch at least on mine simple pops the back end to the open position about an 1 1/2" open tilt.
I would try apply some grease along the full length of the track to see if that helps your auto open.
Old Feb 20, 2010 | 08:38 PM
kiyakerz's Avatar
thanks for the info, what kind of grease should I get? Is this something I can pickup at my local autozone?
Old Feb 20, 2010 | 08:48 PM
PadawanKnight's Avatar
You need to reset your sunroof. There are multiple threads on here about it. The process is different for the 5.5 Gen vs. the 5th Gen, so make sure you're reading about the right Gen.
Once reset, the "full" button will operate the tilt function of your sunroof. The other button will operate the slide function - with a full press (indicated by a click feeling) will fully open/close the roof automatically.
Old Feb 20, 2010 | 08:49 PM
Ghost_54's Avatar
Yes you can get it at any local auto supply store, just a light weight grease usually in a small tub or tube, (you don't want a spray on) so one you can apply with your fingers.
Old Feb 20, 2010 | 08:58 PM
kiyakerz's Avatar
I was able to reset my sunroof, but it looks like it will definitely need some grease. It was struggling big time to open and close which is probably the reason it needed the reset in the first place. Thanks again the help
Old Feb 21, 2010 | 02:56 AM
Gemner's Avatar
it needed to be reset because the battery was disconnected and the reset was never done after.
Old Feb 21, 2010 | 01:53 PM
kiyakerz's Avatar
I cleaned out the tracks today with some paper towels, used some lithium grease I found at autozone and now the sunroof is working like new
tarun900
19
Dec 20, 2021 06:57 PM
bigdogsteve
Jan 31, 2018 04:18 PM
jonreidhead
Jan 6, 2016 09:38 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
