please help
Old Dec 6, 2001 | 11:14 PM
flipmode_cali's Avatar
please help
i have a 5 gen and im trying to take the shift **** off how do i do that, the damn thing is hard.
thank
travis
zero tolerence
Old Dec 7, 2001 | 12:18 AM
ToYLeT902's Avatar
JET Speed Lab
take a cloth, put it over it, take a wrench of some sort, and twist like a ****... i forgot which way though.. and you'll have scratch's on your shifter... i think it was.... counter clock wise.
Old Dec 7, 2001 | 12:38 AM
emax02's Avatar
Or you could try heating it up with a hair dryer and turning the **** left. The **** is glued down I believe so heating it up will probably help break it loose.
i did what you said and the **** just keeps spinning
how do i take it off completely
Old Dec 7, 2001 | 01:01 AM
Originally posted by yo_its_ok
keep turning ... and then yank the B!tch off ...
then how do you know when it free from the threading
Old Dec 7, 2001 | 01:04 AM
Colonel's Avatar
Old Fuddy Duddy
It takes a while to spin off. I.E. there is a lot of thread and the know is all the way down. I spun a while and tugged every once in a while when I thought I was almost done. Eventually it just popped off. If you have it "unseated" and can spin it, its just a matter of patience at that point to get it all the way off.
Old Dec 7, 2001 | 01:19 AM
can you tell how to remove the shift boot
Old Dec 7, 2001 | 11:10 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
It MAY be possible to remove the boot without removing the console.
It is held at the base by a square shaped ring(actually part of the boot) that snaps around all the sides into the console. Just pull on the bottom of the boot towards the shifter one side at a time.
Until you've seen it though it might be easier to just remove the console.
What boot are you going with? I tried the MOMO Elegance and unless you go with a MOMO/aftermarket shift **** with a FAT base, it doesn't fit/look right.
I'm going to try the MOMO Universal once I return the Elegance.
Old Dec 7, 2001 | 12:26 PM
adman's Avatar
yes i agree...righty tighty..lefty loosey ?
Oh, no...not this again???
ADMAN
