what size is your aftermarket rim??
im shopping around for rims and im debating between getting 18" or just go with 20" just what some feedback on what you guys are rolling on thanks in advance
But you have to take in consideration the tires as well as the rim size. 1 inch makes a hell of a difference
Anything over an 18", unless you're going strictly for a show-car, is pointless. And well, lifted on dubs just looks ridiculous.
Btw, where'd you get that grill from? Custom, or ordered? I thought those were only made for the 5th gens.
Ive had:
15s <-- winter set, z31s (current) -- Too small
16s <-- track wheels/summer z32s (current) -- Too small, although light
17s <-- Stock (sold), Mille Meglia (sold) -- Too small
19s <-- Motegis (sold) -- Too big
Go with 18s for a 5th gen
I got 19"....20 is too big and looks goofy on a 5th gen. It also depends on the style/color of the rim as that will deceive the eye making the wheel look bigger/smaller than it actually is.
The 18" posted above doesn't look too bad and the extra 1" on the sidewall will definitely help with ride comfort.
You can go with 18s, 19s, or 20s, on a 5th gen and make it look good. The big secret is picking the correct tire size. If you keep the same relative overall diameter you'll be fine.
And if you havent touched your suspension yet, dont get rims...
i've stuck with 17's on my Max, 5Zigen FN01RC Titanium Bronze, on a super black. still riding on stock suspension, and at 15lbs a rim cant go wrong. 225/45/17 tires.
On the grille, it's an old JMS grille I got lucky with in the classifieds here on the org. From what I understand the company that made it is no longer in business but to tell you the truth it isn't hard to make. It's just expanded metal mesh that has been cut to size then pressed into a die. I guess the real thing that set this grille apart was the primer coat they put on the grille.
The 5th Gen comes with 17's. If I was going to change rims, I would go with 19" rims. Going to 18" just does'nt justify the expense and 20" rims are too big and look stupid IMO.
But going to 19's you will have limited choices for rims & tires. Something to think about?
Something else to think about is tire manufacturers make lots of tires in the 17 19 and 20" sizes and you will find those to be pretty cheap compared to what you find in a 18" size. On average 17s, 19s and 20s were a minimum of $20 cheaper per tire than they were for my 235/40/18s.
Sometimes. Ive seen 19" tires go for $100 more than 18"s. And some tires not even offered in 19" sizes...
To me Maximas look mofre like a luxury style vehicle than a traffic ripper, so I personally am doing 19" "dubbish" style rims, nothing too crazy or too much though, I like them with a bigger rim with a deep dish, I just find it suits the car best for my tastes, but nothing cheesy
well my wife's altima waterpump crap out so the money i had for the rims went to fix that, but on a lighter note im picking up a set of OEM 350z rims with tires for $100 guess that will do for now.
Well op if your considaring a nicer ride into your purchase than you should exclude 19"+ cause it only gets worse. I have 18"s and they fit and fill perfect. I love the look I also like the look of 17's on a nice drop. It just doesnt look to over done. it is still clean looking under 19"
Either way....good luck with your decision.
Jake
Jake
I had 17in Z rims from a 2003 on the Max but I messed up my rear ones in a hydroplane accident. I now have 18in Z rims from a 2005, I'm also running 3 and 5mm spacers. You can still rotate the wheels even though they're staggered, you can hardly tell the difference, its only a half inch. Or if you prefer you can try to trade your fronts or backs with someone so you'll both have the same size.
Ummm no There are more options for 17 and 18 inch wheels than there are for 19 and 20 inch wheels. Not only that you can add a whole LOT of cost to the purchase when you jump to anything larger than 19". On a good tire it can be 75-100 more per tire when going from 17 to an 18. Honstly i'll be going for a 17" wheel since ride, comfort and cost are important on my DD
18's!!!! even though mine are ****ty. anywho. what's the biggest as far as in width goes that you can get for a 4th gen without it looking stupid (where it sticks out or rubs on the inside) 8.5?
