Overheating Problem
Old Mar 2, 2010 | 07:51 AM
StenholmEngineering's Avatar
Overheating Problem
Ok guys this is not Maxima related but i am at a loss and cant figure this out! Did a timing belt, water pump, thermostat and new hoses on a 2000 Xterra with a 3.3. Now it was fine for a few days, then all off a sudden it ran hot. Let it cool off and it was fine for a few days then it will get hot again then its fine. Then its overheats again....wtf is goin on lol. Its not at any certain point or anything that is triggering it that i can think of. I really cant figure this lil sucker out. It goes days without any issues at all. . any ideas?????
Old Mar 2, 2010 | 07:57 AM
Feldman's Avatar
how is your coolant level? could you have air in the system?
Old Mar 2, 2010 | 08:03 AM
Amave's Avatar
/\ agreed air in the system could cause an overheating issue.
i would just let it run hot ( but not overheat ) hen keep the overflow tank full, when the engine cools it will create a vacuum and suck in the coolant in the overflow and purge the air out.
if you do this and it still overheats then you may want to look into it further
Old Mar 2, 2010 | 10:11 AM
Feldman's Avatar
when your car starts overheating does your heater still blow hot air? if not you have a flow problem wether it be an air bubble or malfunctioning thermostat.
Also on the maximas i am pretty sure there are two thermostats i bet the xterra is the same. I think one is called a flow control valve or something like that but they both work the same way might want to check into that. Or maybe the thermostat you replaced is sticky.
Just some thoughts
Old Mar 2, 2010 | 11:06 AM
yeah it is just weird cuz it isnt all the time....idk im going to bleed the sytem and check in the haynes for a secondary t-stat. also gonna check and see about that flow issue wit hthe heat...thanks for the help guys!
Old Aug 24, 2010 | 01:10 PM
YUOnDaGround's Avatar
Good luck and let us know how it turns out.
Old Aug 24, 2010 | 03:46 PM
2slow's Avatar
hmmm... I think I recently saw something that fits here....
Originally Posted by NmexMAX
And we bumped this thread why?
Old Aug 25, 2010 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Increasing postcount for Mr.YUOnDaGround
Old Sep 7, 2010 | 01:20 PM
Not really, just want to know what he comes up with. Sometimes folks forget to update and the thread dies. This way if he subscribed to his own thread than he may get an email to remind him. My car just got towed to the shop on Sunday night. I hope it is a waterpump but it may be a blown head gasket.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
