Wheel Spacers...
Old Mar 8, 2010 | 10:32 PM
VQtHuRtY's Avatar
Wheel Spacers...
Close
Old Mar 8, 2010 | 10:55 PM
VQtHuRtY's Avatar
Close
Old Mar 9, 2010 | 12:10 PM
Prophecy99's Avatar
I have -18x7.5 35mm and tires are 225/40/R18 running 20mm rear spacers.... still room for a tad more mm in the back on that setup. hope that helps.
That being said I would say 20mm rear spacer would be close if they are 45 offset. If your willing to roll fenders you may be ok. If not willing to roll them i would play it safe and do 15mm spacers, if you don't install extended studs with the 15mm spacers you should be able to clear those dust covers with 5mm spacers on the existing studs.
Truly theres only one way to find out though. By measuring.
Old Mar 9, 2010 | 12:53 PM
Gemner's Avatar
10mm front and 20mm rear. I have +45s and using 10mm front and 25mm rear I had to roll the rears AND center the beam for them to not rub. In the front though with +45 I think you would be safe with 15mm but it might look funny
Old Mar 9, 2010 | 01:00 PM
Deckdout2's Avatar
Play with my balls
I guess you like what you like. Not my taste personally.
Old Mar 9, 2010 | 01:33 PM
spydermonkey's Avatar
Originally Posted by VQtHuRtY
The wheels are the KMC SR7 with the optional lip. The wheels have a really agressive look to them and are really light weight. Come on peeps, what spacers should I use to to clear the ball bearing dust cover and add a more agrresive stance to it?
What do these look like without the optional lip? Any pictures the actual wheel? No clue about your spacing issue...rollin on stocks myself.
Old Mar 9, 2010 | 06:39 PM
Prophecy99's Avatar
yeah they...are far out...there
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
