2000 dash lights wont work
Old Mar 9, 2010 | 04:28 PM
Jereme329's Avatar
the dash lights in my 2000 wont come on when i turn my headlights on. the dash lights are on when my headlights are off though. not sure whats going but i think it might have something to do with the way my radio is wired because the guy that had the car before me raped my radio harness instead of just buying the aftermarket harness, were would i be able to get the stock radio harness and could this be my problem?
Old Mar 9, 2010 | 09:56 PM
Jereme329's Avatar
anyone have any ideas?
Old Mar 10, 2010 | 12:05 PM
dnozzle2789's Avatar
front Illumination switch..? is my best guess
although my dash lights wouldn't come on at all, headlights on or off.
Old Mar 10, 2010 | 10:28 PM
DennisMik's Avatar
I'm assuming that the previous owner cut the connectors off of the wire harnesses. There were 2 connectors for the radio. If you want to replace the wire harness, I guess you only have 2 choices - a junk yard or the dealer.
One of the wires in the big connector (#7) is a red with a yellow stripe. This is from your dash lights to control the radio's front panel. Disconnect this wire and see if your dash lights work properly. To totally straighten this out, you will need to get the pinouts for the radio.
2000 Maxima with Bose Radio Wires:
LARGE PLUG BREAK DOWN
1 – Left Front Negative - BLACK - **Line Level Signal**
2 – Left Front Positive - WHITE - **Line Level Signal**
3 – Right Front Negative - RED - **Line Level Signal**
4 – Right Front Positive - GREEN - **Line Level Signal**
5 – Antenna Signal - GREEN/White
6 – 12V Constant - Yellow
7 – Illumination/Dimmer - RED/Yellow
8 – Light Switch - RED/White
9 – Ground - BLACK
10 – 12V Switched - PURPLE
SMALL PLUG BREAK DOWN
11 - Ground - BLACK
12 – Remote Amp Turn on - GREEN/White
13 – Left Rear Negative - BLACK/Red - **Line Level Signal**
14 – Left Rear Positive - BROWN - **Line Level Signal**
15 – Right Rear Negative - BLACK/White - **Line Level Signal**
16 – Right Rear Positive - BLUE - **Line Level Signal**
If the car did not have a Bose unit originally, the wire colors for the speakers are different, but pins 5,6,7,8,9 and 10 are the same in both versions
Old Mar 11, 2010 | 10:46 PM
Jereme329's Avatar
thanks i will try and figure it out tomarrow
Old Mar 13, 2010 | 12:05 PM
Jereme329's Avatar
i finally figured it out thanks to yualreadyknow908. i had to ground the red and white wire and now they work
Old Dec 26, 2010 | 09:12 AM
gottiejr321's Avatar
i have that same problem how did you fix your? what was the steps you took?
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
beboski
Aug 16, 2015 05:23 PM
kenc15
Aug 5, 2015 08:29 AM
