Vibration
Old Mar 17, 2010 | 07:25 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Vibration
Ok let's do this again. Everything in the front suspension was replaced. Car stil vibrating in the front. Wheels balance 4 times so wondering if the inner tie rods could be the problem. Ball joints and bushings checked.. so what could it be?
Old Mar 17, 2010 | 08:08 PM
MONTE 01&97 SE's Avatar
Slightly bent rim, bad bushings.
Old Mar 17, 2010 | 10:56 PM
artemz28's Avatar
how are ur tires? mine were complete crap, like im talking about 0% tread left, car wheel vibrated like crazy, got em swapped, and it was fine..
Old Mar 19, 2010 | 03:15 PM
Lontar1's Avatar
tires are new, bushings are good.. wonder what's wrong
Old Mar 19, 2010 | 03:18 PM
Amave's Avatar
by any chance did they check the radial force variation on your tires?
if there is too much radial force on your tires you could also get a vibration.
iirc 26 lbs per tire is the max, any more than that it will vibrate, and you will need new tires, in most cases can be replaced under factry warranty as long as they record the # and submit that to the tire company
Old Mar 27, 2010 | 11:57 AM
Lontar1's Avatar
took the car to my mechanic.. bad bushings on the LCA, so buying new bushings in the next few weeks... and finally wil have my car ready again
Old Mar 27, 2010 | 03:05 PM
asta4's Avatar
I'm having a similar issue. I've had the tires balanced 3 times and still have vibration from 60-80. How did you test for bad lca bushings? Please update the thread if they fix your problem.
Old Mar 27, 2010 | 03:16 PM
MAXIMA_STYLE's Avatar
alignment issues.... thats the obvious though..
Old Mar 27, 2010 | 03:58 PM
nismopc's Avatar
Same issue on drivers side but the bushings were fine. The actual rear post that went into the bushing broke at the internal weld. Same effect though.
To test for bad bushings/LCA, the front has to be on the ground to test. If you left the car, the force/weight of the wheels and suspension might not allow you to determine the actual issue.
Put your foot on the top of the tire and push towards the rear of the vehicle. If bushings/LCA are bad, you most likely will see that your wheel moves back and forth and you might even hear the clunking from it.
...good luck!
Old Mar 27, 2010 | 07:40 PM
ghostrider17's Avatar
...good luck!
Uh - is it me, or does this make no sense?!
Foot on top of wheel and push towards the rear..!?
Maybe I've had too many beers on a sat. nite -- but I can't envision this at ALL.
Keep us posted Lontar.....I'm in the same boat -- Passenger side.
gr
Old Jun 26, 2010 | 05:52 PM
Lontar1's Avatar
car fixed no more vibration... LCA replaced and al components in the front.. finally I have my baby back to normal...
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
