Dyno numbers (sucky)?!
Old Mar 22, 2010 | 06:46 PM
McSteve's Avatar
Alrighty guys
i finally got my car dyno tuned. pretty disappointing if u ask me.
Mods are:
Timing advance, Intake, Y-pipe, straight pipe instead of cat, cat-back exhaust.
It was done on a dynapack dyno. It's one of those ones where they bolt it directly to the hub instead of a roll on dyno.
Let me know what you guys think
Old Mar 22, 2010 | 07:40 PM
Grand_hustle17's Avatar
isnt there a dyno section on this forum i though there was..... anyways, the numbers are extremely low... extremely...... any CEL??? knock sensor issues???
Old Mar 22, 2010 | 07:51 PM
McSteve's Avatar
no CEL, it did throw a knock sensor code tho... can that affect the performance that drastically?
Old Mar 22, 2010 | 08:50 PM
rroderiques77's Avatar
Demodded and Forgotten
Not familiar with this dyno, but I am sure the numbers are lower than most. Anyone in the area have a regular dyno?
Old Mar 22, 2010 | 09:22 PM
Child_uv_KoRn's Avatar
Bad *** Newb
KS makes it retard timing. So, yeah, it runs like ****!
I'm surprised it's actually that high with a bad KS.
Old Mar 22, 2010 | 09:25 PM
McSteve's Avatar
doesn't KS only influence idle rpm and not WOT?
Old Apr 17, 2010 | 11:09 PM
Rods03Max619's Avatar
Damn that is crazy low
Old Apr 17, 2010 | 11:16 PM
NmexMAX's Avatar
dot dot dot ...
Hi rookei?! This is a semi old post ...
Anyhow ... That's obviously a Mustang/Dyno dynamics dyno, minimum 30% low vs dynojet ..
Old Apr 18, 2010 | 02:00 AM
McSteve's Avatar
the knock sensor resistor fixed the low end power.... i'll get it retuned after I install headers, we'll see how that'll go
Old Apr 18, 2010 | 06:59 AM
Try dynjet for higher numbers
Old Apr 18, 2010 | 07:26 AM
essential1's Avatar
My axles cry for mercy...
Wheres that link to the knock sensor resistor mod. I need to do it too.
Old Apr 18, 2010 | 10:23 AM
2slow's Avatar
Higher, but not better.
Old Apr 18, 2010 | 10:36 AM
5 ltr. beater's Avatar
yes lower numbers on this type of dyno are normal! don't worry! a couple of M45's on the Nico forums (my other home) reported similar "disappointing" numbers. the average M45 puts down between 252 and 270 on a dyno jet.
however one of the board members went to get his car dyno tuned on a dynapack and put down only 230! almost a 30hp difference!
his gain however was the same as everyone else AFTER the tune, which was about 26rwhp more. so even though his numbers were low, the gain was the same as the M's who had their car dynotuned on a dynojet.
so dont look at how much your car put down, but rather how much MORE did you pick up, from the before an after.
Old Apr 18, 2010 | 10:38 AM
higher numbers don't mean anything. but how much he picked up between the before and after DOES.
Old Apr 18, 2010 | 10:40 AM
yes it can! you're losing at least 6-7 more at the wheels (not to mention crappy gas mileage). as much as you baby your ride, i can't believe you missed something like that. get that fixed asap and go get re-tuned.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
