Timing Advance: ECU Reset
Old Apr 3, 2010 | 11:09 PM
incubusjohnny's Avatar
So i was told that with the timing advance, the ECU would reset to 15 degrees after a while. anyone know if this is true?
Old Apr 3, 2010 | 11:15 PM
viperboy's Avatar
Not true. The timing parameters get set in EEPROM which will not get erased when you reset the ECU.
Old Apr 3, 2010 | 11:18 PM
i was told by two people at Nissan dealerships that said this was true
Old Apr 3, 2010 | 11:53 PM
Child_uv_KoRn's Avatar
Bad *** Newb
And since when can do they do anything except change oil?
Seriously, I'm surprised they could write a resume to get hired haha
Old Apr 4, 2010 | 12:05 AM
Gemner's Avatar
i didnt realize they could even change oil. im impressed
Old Apr 4, 2010 | 04:26 AM
nismopc's Avatar
Only way it would be lost is if they ran another update on the ECU and wiped out the setting which is highly unlikely. Most all updates (TSB's) etc. are a few years old, so unless you havent had those done yet, which is also highly unlikely, you'll be fine.
Old Apr 4, 2010 | 09:13 AM
Unklejoe's Avatar
I believe if they go any more than 2 degrees, the ECU will not retain the settings after a reset.
I also remember reading something about 00-01's being different than 02-03's.
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
t6378tp
Aug 24, 2015 07:03 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
