high performance fan...
Old Apr 4, 2010 | 12:23 PM
20th01's Avatar
Anybody done anything like this?
http://www.slickcar.com/productdetai...?ProductID=121
and have any information on how much B/S is invovled?
Old Apr 4, 2010 | 12:37 PM
Xarles's Avatar
I'm pretty sure the fan is only on when the car is idling and not going anywhere so unless your a cop or soccer mom in florida you shouldn't need that.
Old Apr 4, 2010 | 03:15 PM
NmexMAX's Avatar
dot dot dot ...
The fan is on when the EC has reached a certain temperature, or when the AC compressor is on.
Some people in the FI forum have upgraded both radiators and fan combo's. I think our coolant systems are fine as is, unless you're FI, really NA'd, etc.
Old Apr 4, 2010 | 07:34 PM
SiathLinux's Avatar
I've had this before on several of my cars (Toyota Celica's - old rear drive ones) and both of my 280zx... they are temp controlled (they come with a thermoswitch or you can wire them to your existing fan wiring. They move a lot of air, and in Florida it's a nice addition.
Old Apr 4, 2010 | 07:38 PM
NmexMAX's Avatar
dot dot dot ...
You could just install a manual switch, say for the track or something.
Old Apr 4, 2010 | 07:40 PM
Mr. Brett's Avatar
Unless you're doing some kind of endurance racing or driving for a long, long time in temperatures higher than 110 degrees, I don't see why you'd need something like this on our cars...
I've never had any issues with my car overheating. I've had it get warmer than normal sitting still, bumper to bumper in 100 degree weather at Import Alliance last summer. But that was only because black tarmac + lots of cars = lots of heat.
Old Apr 4, 2010 | 08:04 PM
Scottwax's Avatar
That's Mr. Detail to you
No problems with the stock cooling system here in Texas.
Might be worth it if either of your original fans go out and you need a new one.
Where the power gains with fans come in is when you replace a belt driven fan with an electric one.
Old Apr 4, 2010 | 08:50 PM
20th01's Avatar
Yea I was thinking for at the track in between runs so the engine could cool down faster, also wanted to maybe hook
up a manual switch so that I could turn the fan on while the car was not running in the waiting lane, I eventually
want to do a subtle turbo or supercharged set up with it and the last turbo car I had got pretty hot, but it was a 4 cyl.
Old Apr 4, 2010 | 09:36 PM
Mr. Brett's Avatar
Are you talking strip or road courses, though?
Old Apr 7, 2010 | 04:45 PM
20th01's Avatar
strip
Old Apr 7, 2010 | 05:27 PM
Mr. Brett's Avatar
I think if your car is NA, you'll be quite alright at the strip with your OEM fans.
Spend that money on some worthwhile mods that'll give you bigger gains.
Old Apr 7, 2010 | 09:06 PM
DennisMik's Avatar
My cars do just fine here in Texas. Could I suggest that you go run your car on the strip and see what happens before you spend the money on fans. I think you won't need the fans.
Old Apr 8, 2010 | 06:05 AM
2slow's Avatar
Unless you already experience excessive coolant temperatures, this is unnecessary. If coolant temperature was an issue, I would first look to upgrading the thermostat (if possible for these cars), then the radiator and then the cooling fan(s).
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
Socalstillen
Sep 26, 2015 12:01 PM
