Coilovers just not participating...
Old Apr 9, 2010 | 10:05 PM
e-subliminal-2's Avatar
K-sports in. Front look beautiful. My problem comes from the rear. The lowest perch hasn't been touched in what seems like FOREVER. The WILL NOT BREAK LOOSE!! Not the locking perch and the perch below the springs, The farthest one down. They're Kontrol pro's btw. Any luck? I've tried drowning them in wd40 and pb blaster...
I was trying this with them on the car. Bolted in. I figured i'd break that lower perch up than take the lower strut bolt out and spin it up to adjust ride height...
Any help would be appreciated..
Thanks.
Old Apr 9, 2010 | 10:14 PM
Mr. Brett's Avatar
I read somewhere earlier. Moncef said he was getting his seized coils heated. And Ghustle was going to try the same because the PB blaster just wasn't cutting it.
Old Apr 9, 2010 | 10:22 PM
IHAVEA2KMAXIMA's Avatar
Place the wrench in place and use a mallet to progressively hammer the lock ring loose.
Old Apr 9, 2010 | 10:48 PM
Tried.. Looked like my hammer would break before that damn perch came loose..
Old Apr 9, 2010 | 10:50 PM
Using a torch or a basic lighter?
Old Apr 9, 2010 | 10:54 PM
Mr. Brett's Avatar
I dunno. He said he took it to a shop and told them to "gently" heat them up. I'm supposing they'll use an acetylene torch or similar. Just make sure if you heat them to not do it too much. If your coilovers are made of aluminum, there's a potential for the heat to make them warp extremely easily.
Old Apr 9, 2010 | 11:02 PM
Then maybe get a friend to help you. Place two wrenches and one of you can pull and the other can push. Yank it a couple times.
Old Apr 9, 2010 | 11:03 PM
Since I have no choice and have basically skinned my hands trying to break those perches, I'll give this a try tomorrow..
Old Apr 9, 2010 | 11:24 PM
914Max914's Avatar
wow i thought just hitting it with a mallet would do the trick? thats crazy. i figured using somthing like a chisel or a big flat headed screw driver and wacking it would the mallet would break it loose hmm good luck bro
Old Apr 9, 2010 | 11:33 PM
Yeah, I hit it about 40 times before realizing that wouldn't work.. Will try again tomorrow before torching it..
Old Apr 9, 2010 | 11:43 PM
I tried hitting the mallet against the tool. I'm going to try against a giant flat head first. If that doesn't work.. I'll be back here.. I'm not looking forward to torching my coilovers just yet tbh..
Old Apr 10, 2010 | 02:52 AM
I just dont think heating it is a good idea especially there is compressed gas inside.
Old Apr 10, 2010 | 07:29 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Torching is the only way to get it off, though.
Please, don't use acetylene That's WAY too hot. Just use a hand held propane.
Old Apr 10, 2010 | 10:27 AM
43 hard hits with a huge flathead and a hammer,it's off.
Old Apr 10, 2010 | 12:32 PM
Mr. Brett's Avatar
Thank you for correcting my mistake before he blew his coilover to kingdom come.
Old Apr 10, 2010 | 02:52 PM
SteveB123's Avatar
If he heated a compressed gas with a torch, destroying the coilover might be the least of his worries.
Boom no good.
Boom bad.
Stay away from boom.
Old Apr 10, 2010 | 05:03 PM
Boom no good.
Boom bad.
Exactly why I just beat that perch with a mallet like i'm it's daddy
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
