R-Tec 3" MAF aluminum adapter - Cheap alternative for custom intakes (pictures)...
Old Apr 14, 2010 | 07:30 PM
nismopc's Avatar
Searching eBay for the normal "Nissan" stuff, I came across some Sentra and 350Z MAF billet aluminum adapter's with 3" opening . I looked them over, did some research and found they are the same design as the Maxima.
Ordered the adapter for $11.90, it was shipped in less than 4 days and I'll let the pictures do the talking...
The seller is superautobac and here is a link to the one I purchased:
http://cgi.ebay.com/ebaymotors/ws/eB...m=350309927340
Great for those who want to build a hybrid/custom SRI/WAI...
Old Apr 14, 2010 | 07:34 PM
pepox369's Avatar
nice.. good to know.. im planing on doing this real soon!!
Old Apr 14, 2010 | 07:49 PM
PulsarGTS's Avatar
I bought a similar one at pepboys. Yes pepboys...
Old Apr 14, 2010 | 08:00 PM
Unklejoe's Avatar
I bought that exact one on eBay about three months ago. The inside diameter is actually smaller on the adapter than it is on the MAF, so I swapped it out for the plastic one on eBay that has thinner walls on the piece of tube that sticks out.
I made a thread on it somewhere.
If you look through the MAF tube, you can see that the walls of the adapter are about 2mm smaller all the way around.
Old Apr 14, 2010 | 08:23 PM
nismopc's Avatar
Damnit! Your right...
...well, back to the drawing board.
I had the plastic black one from eBay and it dry rotted to hell. Ended up snapping at the bolt holes. ARGH!!!!!!
Old Apr 14, 2010 | 08:33 PM
Unklejoe's Avatar
It is built too well lol, too thick(the aluminum one). I can't seem to find the one that I bought on eBay anymore either.
I'm sure it will pop up soon though.
The only problem with mine is that is it plastic, so you have to be careful how you mount it as the vibrations can crack the screw hole if it is only mounted with one hole.
But, your mounting job looks far better than mine.
Old Apr 14, 2010 | 08:38 PM
nismopc's Avatar
Old Apr 14, 2010 | 08:55 PM
Xarles's Avatar
Does this make more horsepower then a "normal" SRI? I would imagine so because it cuts out 6' of pipe but I dont have it so whats your take afterall you've got the experience?
Old Apr 14, 2010 | 09:03 PM
nismopc's Avatar
Huh?
Mine is a typical custom SRI/WAI...
The MAF sits almost identical to where it did when it was connected to stock helmholtz resonator and stock airbox.
Old Apr 14, 2010 | 09:31 PM
Gemner's Avatar
if you ever have to buy a new MAF, it usually comes in the tube, so you can use either the new tube or the old tube and cut the flange off. Then just put the filter on the end of the tube
Old Apr 15, 2010 | 02:31 AM
Xarles's Avatar
Sorry when I looked at the pic it looked shorter, I'm not getting enough sleep so i do stupid things, oh well. Thanks for the correction
Old Apr 15, 2010 | 05:58 AM
essential1's Avatar
My axles cry for mercy...
+1
I just bucked one from the junkyard and cut it in half.
Old Apr 15, 2010 | 06:42 AM
NmexMAX's Avatar
dot dot dot ...
Dual MAF housings FTW!
Old Apr 15, 2010 | 07:21 AM
nismopc's Avatar
Hell yea!
I always attempt to do the OEM look on all my DIY'ers...
Old Apr 17, 2010 | 12:46 AM
a33_ridah's Avatar
so whats the conclusion???
the 2mm diff on all side (diff diameter) a big issue in air flow??
Old Apr 17, 2010 | 01:01 AM
Gemner's Avatar
yes, considering the MAF tube is already smaller than it ought to be you shouldnt be shrinking the ID of the intake system more
Old Apr 17, 2010 | 04:37 AM
knight_yyz's Avatar
Toolie
that's a great deal for a nice adapter but he wants 23 US to ship it to Canada!! IF you guys want one with a thin wall buy the vibrant adapter for the subaru, then drill your own holes. the wall is less than a millimeter thick.
Old Apr 17, 2010 | 07:01 AM
NmexMAX's Avatar
dot dot dot ...
Come on man .... you're the man, make your own .. you made mine. Also, 3" ID will require some dramatic MAF correction.
Old Apr 17, 2010 | 07:39 AM
Unklejoe's Avatar
I don't think the I.D of the adapter will matter.
You were probably referring to the I.D of the actual MAF tube, right?
Old Apr 17, 2010 | 07:42 AM
NmexMAX's Avatar
dot dot dot ...
Very true and that was my indirect point as in your flow is only as good as your smallest ID.
Old Apr 17, 2010 | 07:51 AM
Unklejoe's Avatar
Yep. I had that adapter and I tried to tell myself that the 2mm won't matter, but I just couldn't sleep at night.
I bought the eBay plastic one that has thinner walls, but I can't seem to find it on eBay anymore.
And the fact that your flow is only as good as your smallest I.D is what is keeping me from getting a 3" exhaust, until I do a 3" y.
Old Apr 17, 2010 | 08:56 AM
jbrooks870's Avatar
A 3 inch adapter doesnt do much unless your MAF is 3 inch
Old Apr 17, 2010 | 09:05 AM
NmexMAX's Avatar
dot dot dot ...
I see people are putting it all together now. : D
Old Apr 17, 2010 | 09:14 AM
jbrooks870's Avatar
3 inch all the way with a bigger TB is the way to go
Old Apr 17, 2010 | 12:36 PM
NmexMAX's Avatar
dot dot dot ...
Let's not get ahead of ourselves now.
Old Apr 17, 2010 | 01:32 PM
Unklejoe's Avatar
I have yet to see anyone actually bore the throttle body out on a Maxima. I've heard of a few of the Z guys doing it, and they have the same throttle body so...maybe...
Old Apr 17, 2010 | 01:41 PM
NmexMAX's Avatar
dot dot dot ...
Why bore? Find a larger unit that fits with minimal modification ... Mustang comes to mind ...
Old Apr 17, 2010 | 02:26 PM
Unklejoe's Avatar
Are the newer Mustangs DBW?
Old Apr 17, 2010 | 02:59 PM
knight_yyz's Avatar
Toolie
someone has already used a corvette TB on a Z...
Old Apr 17, 2010 | 03:37 PM
NmexMAX's Avatar
dot dot dot ...
Corvettes FTW!
Old Apr 17, 2010 | 06:07 PM
nismopc's Avatar
Well, I'm gonna stick with it for now. Fitment is superb, looks good and car still feels the same to me.
Unless my butt-dyno is off...
...and no I'm not gonna get it re-calibrated!!
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
95Maxi
Aug 29, 2015 09:38 PM
Samedi
Aug 13, 2015 04:05 PM
