anyone here bypass bose amp manually? what pins on harness to use?
Old Apr 14, 2010 | 11:25 PM
kingrukus's Avatar
no more maxima...
anyone here bypass bose amp manually? what pins on harness to use? I basically want to "jump" past the bose amp, by wiring the input harness directly to the output harness for the front two speakers/tweeters. What wires/pins to do this with on the harnesses?
The plan is to install an aftermarket deck, then power the front speakers off of of (I will be replacing the bose fronts with some 4ohm speakers). I will leave the rest of the bose system unpowered.
Old Apr 18, 2010 | 02:14 PM
kingrukus's Avatar
no more maxima...
bump.................
Old Apr 18, 2010 | 03:44 PM
CraigSE's Avatar
My suggestion is to get a deck, check out the wiring schematic, and run new wires, which is a piece of cake. Problem solved.
Old Apr 18, 2010 | 04:20 PM
kingrukus's Avatar
no more maxima...
I was hoping to basically splice into the stock wiring, rather than run new wiring into the doors - that can sometimes be a PITA.
Old Apr 18, 2010 | 05:08 PM
Unklejoe's Avatar
I did just that. Sorry, but I don't have the schematic anymore, but I assure you it's on here somewhere.
I just replaced the Bose amp with another (better) amp.
The car basically already has two sets of shielded low voltage wire pairs running to the back of the car.
Makes everything a lot easier.
If I understand correctly, your plan is to go directly from the front speaker output on the deck, through the stock line wire, and from that, just bypass the amp?
That would probably work, but I wouldn't want to feed amp level currents through the thin wire that feeds the input of the stock Bose amp. This wire is designed for low level signal, not really amp level, but you could be OK.
Old Apr 18, 2010 | 10:49 PM
a33_ridah's Avatar
im sorry i may not be too much help here.
BUT
i have had my bose completely "blocked" for one all speakers and tweeters were replaced with mb quart. deck a kenwood dnx 8120, bose amp somehow bypassed and powered from the deck. clean as *&^% sound all the way around.
my installer did it
Old Apr 19, 2010 | 08:34 PM
yamahaman88's Avatar
http://maxima.theowensfamily.com/audiowiring.asp this helped me out alot when doing my audio..its for 5.5 but im just putting it out there.
Old Apr 20, 2010 | 06:01 PM
CraigSE's Avatar
BUT
my installer did it
Somehow? :P
He wired around the amp and just treated it as if everything were a new install.
It's the best way to do it, and really not hard.
Old Apr 20, 2010 | 09:29 PM
a33_ridah's Avatar
sorry to be vague.
it was a clean mobile install job while i was working. i gave him the job. he told me what he did. and yes explained to me it seemed simple
Originally Posted by CraigSE
Somehow? :P
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
jwright36
Sep 8, 2015 11:45 AM
