Coil/ECU problem
Old Apr 16, 2010 | 02:10 PM
Gemner's Avatar
Coil/ECU problem
Im currently getting no signal to cylinder two coilpack. There is voltage and ground supplied fine to the coil, but the signal that tells the coil to fire is not getting to the coil. Ive checked for continuity and it is good all the way from the ECU connector to the coil, so im guessing that means the ECU is not sending a signal to the coil. Does this mean the ECU is toast?
Old Apr 16, 2010 | 03:15 PM
Unklejoe's Avatar
Try taking apart the ECU.
The coil trigger is most likely operated by a transistor.
Look for 6 of the same transistor and check those for proper readings.
Also note that the injectors may also have 6 transistors, so try to trace the leads on the PCB if you can.
I don't know what the ECU looks like on the inside, but most of the components on it are probably replaceable.
Old Apr 16, 2010 | 05:17 PM
Gemner's Avatar
ugh that sounds awful. Any idea where i would be able to buy one of these in the case it IS replaceable?
Old Apr 17, 2010 | 09:06 AM
NYCMaxima01's Avatar
check the wireing from the computer to coil pack
Old Apr 17, 2010 | 01:36 PM
Unklejoe's Avatar
You can try Digikey.
Figure out exactly what is blown, and do a google search on the component (it should have numbers on it).
You can also try eBay, but they have been known to carry "fake" transistors lol
Old Apr 17, 2010 | 01:57 PM
Gemner's Avatar
nothing on the board is replaceable without soldering and somehow I cant find where the transistors are. There are really only a few places they could be but I cant trace any of the wires back to the right pin, so Im probably just going to get a new one. Unfortunately
Old Apr 17, 2010 | 02:25 PM
Unklejoe's Avatar
See if you can borrow a known working ECU before you drop the ball and buy a new one. Good luck
Old Apr 17, 2010 | 07:55 PM
Gemner's Avatar
well, im not going to get a NEW one, Ill get a used one and deal with it from there. Its gonna be a bit since I have to work it all out with TS, I dont want my $400 ECU with special tune to just hit the garbage. I was thinking about taking the ECU to an electronic parts specialist and seeing what they say. Just have to figure out what kind of "specialist" would know how to deal with it
Old Jun 18, 2011 | 05:23 AM
TravisCadello's Avatar
ever figure this one out? im in the same boat with two coils.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
