will it look weird?
will it look weird?
i lowered my maxima on maxspeed springs and im having a real bad rubbing issues in the rear im currently running 245/45/18 in the rear and i hit dips or bumps in the road it rubs. i even rolled the fenders and that helps a bit but not much. what im trying to get to is if i put back on the strock suspenstion will it look all off or will it look ok?? any suggestions??
245/40 will fix it. I am pretty low(sprints) and only bottom out once in a blue moon. I had 245/45 on my stock suspension and I'd bottom out every now and then, I can't imagine lowered with that set up.
the 245 isnt to wide?? in the front im running 225/40/18 and the rear is 245/45/18. i want to run the same size all around im was thinking about doing 235/40/18 this way i have the same size all around
if you run 235/40/18 that is the correct size. and 245/35/18 would be the correct size. but 245/45/18 is WAY to big never put thos on the front or your speedo will be off by like 10mph
. Plus, wider is always better.
225/40/18 is the incorrect size for 18" wheels your speedo is off by 3mph. and there for setting your tach off. with 225/45/18 is the correct size....well super close its only off by like .3% from stock
A 235/40-18 is a smaller tire than the OE 225/50-17 in terms of load capacity. To get that back, I think you'll need to run your inflation pressure up about 3 or 4 psi over what the car's sticker pressures say.
If it was any worse than that, I'd tell you to keep looking for a better size.
Norm
Norm
AaronL
Nov 15, 2020 11:52 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
