Brake Pad wear on z32/cobra BBK
Old Jun 12, 2010 | 08:55 AM
tobe2be's Avatar
So i recently upgraded my brakes on my 5.5 and i'm wondering if my wear pattern is normal which i doubt. So i have z32 4 pots w 13'' re-drilled cobra rotors. I was hearing a weird nose from the braking system so i decided to peak around and see what i found. Here are the pics of the pads.
As you can see the brake pad isnt completely sitting on the rotor which causes that lip on my rotor. Also the center section of the brake pad was packed with brake dust which might have been causing my squeeking type noise. Im not sure if this is normal as this is my first 5.5g and my first z32 BBK. Thanks in advance
Old Jun 12, 2010 | 09:48 AM
McSteve's Avatar
I had the same issue and it was even worse because I had my rotor milled down 3mm. It made a REALLY loud noise. When I reinstall it, I will grind down the break pad a bit before installing.
So from what I have gathered that's normal
Old Jun 12, 2010 | 10:25 AM
tobe2be's Avatar
would it be a smart idea to grind the brake pad down on an angle at the top?Whats odd is that i only get noise from my passenger side and non from the driver side.
Old Jun 13, 2010 | 07:31 AM
essential1's Avatar
My axles cry for mercy...
Mine is the same. Other than my warped rotors, I have no weird noises or anything.
Old Jun 13, 2010 | 08:01 AM
perkman87's Avatar
I have popping noises, and my pads wear the same.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
