Transmission slips out of gear
Old Jun 21, 2010 | 06:46 AM
evalyn's Avatar
01 SE AT. I had my transmisison replaced with a rebuilt core at 108K. A month ago, at 118K, the transmision slipped out of gear and car revved freely unless I put gear shift in 1. Parked and let it sit for 2 hours, turned it back on, and no problems.
One week later, SES light. Took it to my trans guy: Code P0720 output shaft speed sensor circuit. He says "let's clear it and see if it comes back." Now I'm at 119K, and trans just slipped again, and SES light is back on. I will be taking the car back to the trans guy this week. Any suggestions?
Old Jun 21, 2010 | 07:22 AM
maximal01's Avatar
replacing the sensor may actually be the fix, because it controls the rpms of the gears a malfuctioning one may cause the slips and it to over heat making you wait 2 hours or it maybe a safty the engine has i dont know to much about sensors but id go that route first
Old Jun 21, 2010 | 07:26 AM
Max_nino's Avatar
my car does the same thing. does it sooner if i have the A/C on. im not sure what im gonna do.I had the tranny rebuilt last year. good luck and keep us updated
Old Jun 21, 2010 | 11:35 AM
cashoit's Avatar
since u got the code check the circuit for shorts and loose connections. Test the sensor per FSM and/or replace
Old Jun 22, 2010 | 09:24 PM
evalyn's Avatar
Thanks for all the tips. Got the vehicle speed sensor replaced today under warranty. We also cleared the code. I'll post back in a couple days if all is well.
Old Jun 23, 2010 | 04:47 PM
higney85's Avatar
When you say "vehicle speed sensor" are you meaning the "revolution speed sensor" or are they seperate?
Old Jun 24, 2010 | 05:08 AM
Wildcat_Max's Avatar
They are different as per FSM. Revolution sensor: Detects output shaft rpm and sends a signal to TCM. Vehicle speed sensor: Used as an auxiliary vehicle speed sensor. Sends a signal when revolution sensor (installed on transmission) malfunctions.
Old Jun 24, 2010 | 05:27 AM
higney85, did you had a chance to swap all the three sensors (Maf, TPS & Rev. Sensor)?
Old Jun 24, 2010 | 05:44 AM
Tukata's Avatar
My 01 is doing the same thing right now.
Very intermitent until yesterday and no code anymore.
Old Jun 24, 2010 | 08:47 AM
higney85's Avatar
Yea, but I didn't do a relearn/calibration since I evidently didn't research enough. I had some extremely jerky acceleration when I went for a test drive. I had to call it a night to pack for a trip so when I get home tomorrow afternoon I will do the relearn and see what that yields. I'll update my thread afterwards. Still concerned it could be something else, my issue seems to fall under many different threads with many different (and collectively expensive) solutions.
Old Jun 25, 2010 | 07:38 PM
Max_nino's Avatar
The only code mine threw was the speed sensor, i replaced it and it does the same thing.im gonna try to borrow a TCM and if that doesnt work im gonna just go ahead and buy a tranny and replace it. i saw one for 300 with 85K so that would be my best bet being low on cash and all.
Old Jun 27, 2010 | 05:39 PM
PBMAXX's Avatar
I had the same code. I called Daveb and searched the org. and it turns out it is the Output Revolution Sensor located just behind the driver side front wheel. Daveb shipped for $130. It took 30 min. to install. Phillips head screwdriver and 10mm socket is all u need for the install aside from taking the wheel.Good Luck!!!!
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
