Help with code PO507
Old Jun 25, 2010 | 09:27 PM
se_nismo's Avatar
Today i worked on a 2002 maxima, replaced a leaking radiator and cleaned the Throttle Body because i noticed tons of oil/carbon build up in the throttle body..Im sure you know where this is going..after the cleaning idle stayed higher than usual roughly 1,200 rpm and check engine light came on with code PO507 idle speed to high..at lower speeds if i put load on the car with jerks randomly.
I did a search and of course too late noticed cleaning the TB is a bad idea because of the butterfly staying open. I attempted the Idle Air Relearn procedure and the Idle actually dropped to its normal 700-800 rpm..Problem is once turning the car off the idle goes back to 1,200 rpm. Reading more about the Idle Relearn Procedure actually takes a few attempts for the TB and computer to relearn the new position..My question is tomorrow i will perform the relearn procedure several more times, but knowing the idle does drop after the procedure is this a good sign it will change and go to factory idle after X amount of relearn procedures or is there still a possibility of having to replace the IAC or PCM?
Btw: does the IAC Come separate from the Throttle body? Any helpful Input would be greatly appreciated (any thing im missing?)
Old Jun 26, 2010 | 09:17 AM
se_nismo's Avatar
bump!
Old Jun 26, 2010 | 09:42 AM
P. Samson's Avatar
Firstly, you do not have an IAC valve (used on Gen. 5 and prior cars). You have the electronic fly by wire TB. Therefore the issue with the IACV frying the ECM is not an issue with your car. Before assuming that the TB is hooped, try accomplishing the "Accelerator Pedal Released Position Learning" and the "Throttle Valve Closed Position Learning" procedures first, and then the "Idle Air Volume Learning" (without Consult ll) on page EC 71 in the FSM, which you can find a copy here: http://www.nicoclub.com/FSM/
Old Jun 26, 2010 | 10:54 AM
se_nismo's Avatar
Awesome I'll try that process and report back...thanks
Old Jun 29, 2010 | 05:15 PM
se_nismo's Avatar
Update:
Today I performed the Idle Air Volume Learning procedure several times..same results just did not save the required idle setting..once I turn the car off and restart idle goes back to 1200 rpm.
I took the car to the nissan dealer today to see my friend that is a tech. Hooked up the Nissan Consult and attempted the Idle Air Volume Learning via consult but would not allow to make changes...my nissan tech buddy is recommending to replace the Throttle Body and go back so he can attempt the relearn process again.
Any thing else I should be doing? A brand new throttle body is pretty pricey, would I be ok finding a used throttle body?
Old Jun 29, 2010 | 06:07 PM
se_nismo's Avatar
looking for a used throttle body..AutoZone Carries them for $116.00 with $15.00 core..anyone have bad experience with these units? Quite a difference from a brand new dealer throttle body $600.00 unit
Old Jun 29, 2010 | 07:58 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Junkyard time. Maybe a 6th gen TB is better I used one. It worked great.
Old Jun 29, 2010 | 08:08 PM
LongIslandMax's Avatar
Car-part.com
Old Jun 29, 2010 | 10:41 PM
se_nismo's Avatar
found one at the junkyard for $200.00..the autozone one is $130 for a reman with 1 year warranty..going to give the autozone reman a try
Old Jun 30, 2010 | 02:03 PM
chimaxima's Avatar
Wait, Don't buy it right now. I cleaned my TB and had the same symptoms, tried idle relearn procedure many times but no luck and then finally i found out on infiniti forums that if you disconnect the battery for about 10-12 hours leaving headlights on and then do the idle relearn. Trust me it worked for me, i was in the same boat like you but got lucky. One important thing you also have to perform following procedures too before doing the idle relearn.
DESCRIPTION
“Accelerator Pedal Released Position Learning” is an operation to learn the fully released position of the
accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each
time harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
DESCRIPTION
“Throttle Valve Closed Position Learning” is an operation to learn the fully closed position of the throttle valve
by monitorizing the throttle position sensor output signal. It must be performed each time harness connector
of electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
1. Turn ignition switch “ON”.
2. Turn ignition switch “OFF” wait at least 10 seconds.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound
After performing the above procedures then perform idle relearn.Hope fully it will work for you.
Old Jun 30, 2010 | 05:11 PM
arima's Avatar
i did the same thing you did, had the high RPM for over a month w/ check light on. I disconnected the battery and left the car in the garage for a week. connected it back and the car was running normal, check engine light was gone too.
Old Jun 30, 2010 | 09:08 PM
se_nismo's Avatar
I did see that post as well...tried disconnecting the battery overnight still with no luck..even the nissan consult would not program..i really think i need a throttle body in this case
Old Jul 1, 2010 | 08:55 PM
se_nismo's Avatar
picked up the reman throttle body today..have a concern (not sure if its a concern yet) looking at the butterfly it sits at a slight angle...does this matter at all since it hasnt been used or is this the original issue im experiencing? i snapped a couple of pictures
Also looking at this reman throttle body, looks like there is a adjustment screw with a lock nut on it..since i know the throttle body on the car is going to be replaced, would i affect anything if i where to make a last attempt and manually adjust the screw?
Old Jul 11, 2010 | 02:06 PM
se_nismo's Avatar
update: throttle body is replaced and now idle is back where it should be!
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
