testing oxygen sensors for functionality? voltage, resistance?
Old Jul 28, 2010 | 07:34 AM
kingrukus's Avatar
no more maxima...
guys,
can oxygen sensors be tested for functionality? the reason I ask is because I have some used ones sitting around, that I would like to test before installing. is there a specific impedance to test for or any other test to do?
thanks
Old Jul 28, 2010 | 03:07 PM
FanaticMadMax's Avatar
There is a method to check that, it may sound odd and stupid idea, but it's a true and tried method before the OBD came around in the mid 80's. You'll need two things to have, a voltmeter and boiling hot water. put the O2 sensor in boiling water, the tip part, and take voltmeter on the electrical connector and you should get a voltage reading, since O2 mesaure the amount of heat and Oxygen content. If you get a voltage reading then it's functioning.
AaronL
Nov 15, 2020 11:52 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
Steven Orozco
Sep 12, 2015 10:41 PM
