Time for a new transmission. How much should I expect to pay?
Old Jul 29, 2010 | 05:49 AM
2002MaxNJ's Avatar
Whats up guys....
Jumped in the car this morning threw into reverse and nothing.....just revving.
Did a search and it seems that even if I push it out my driveway and get it to where I wont need reverse 1st and 2nd gear will go next soon. What should I expect to pay for a new tranny ??? rebuilt??? AAMCO???? Im in central NJ.
2002 AT Maxima SE 115k
Old Jul 29, 2010 | 05:53 AM
NissanMan97's Avatar
Originally Posted by 2002MaxNJ
Whats up guys....
a quick search on line has found anywhere between 1800 and 600.
look into a MT swap if you want.
id call AAMCO first.
B
Old Jul 29, 2010 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
www.car-part.com
A 6MT swap is very labor intensive (unlike the relative 4th gen swap) and you'll need a new ECU. A bit pricey especially if you just want to get it back on the road.
I would look into a used unit from the website above, preferably in Colorado or another Mountain state. This would ensure that only 70-80% of the cars actual power was ever reaching the ground (high altitude affects power output).
Old Jul 29, 2010 | 06:57 AM
vastmax's Avatar
As a fellow AT driver...this has happened to me twice. As already mentioned car-part.com is your friend. I paid $350 delivered for an 03 tranny with 5000 miles on it and a 1 year warranty, i figured that was too good to pass up.
Old Jul 29, 2010 | 07:02 AM
Deckdout2's Avatar
Play with my balls
You'll pay nothing and like it, son!
Old Jul 29, 2010 | 07:37 AM
denny_1986's Avatar
it went bad overnight w/o any warnings? Under normal circumstances transmissions usually show signs of wear before finally crapping out. I would check for misc sensor problems first before jumping the gun....
Old Jul 29, 2010 | 09:03 AM
2002MaxNJ's Avatar
Its slipping for a while now 2yrs....wouldnt get out first till revving realy high then second would thump in.
Old Jul 29, 2010 | 12:09 PM
Scottwax's Avatar
That's Mr. Detail to you
B
I wouldn't even consider that. Nothing but a bunch of franchise scammers.
AAMCO lawsuits gave me over 6000 hits on Google.
http://www.aamcoscam.com/
http://aamcolawsuit.wordpress.com/
http://www.ripoffreport.com/auto-rep...-jus-bebfq.htm
http://www.rfcexpress.com/lawsuit.asp?id=59802
http://www.consumeraffairs.com/automotive/aamco.htm
http://www.blogcatalog.com/blogs/aam...stigation.html
2002MaxNJ-honestly, I wouldn't even consider having an import transmission rebuilt, no one seems to have the first clue how to do it right, or they simply replace the clutch packs without going through the valve body, torque converter, etc. Like the other suggested, look for the lowest mileage used transmission you can find. Either swap it in yourself or find an independent repair shop who has experience with transmission installs, although not necessarily a transmission shop. Make sure they will flush out the ATF coolant lines prior to installing the replacement transmission.
Old Aug 1, 2010 | 11:34 AM
2002MaxNJ's Avatar
did some research and there seems to be some safety mode for our trans. tried the solution to get it out but no luck. still no reverse and 1 is really slow.
Old Aug 1, 2010 | 04:44 PM
audioshack1's Avatar
I guess you should start looking for a new tran. You can also check out the Junkyard by Shea Stadium in Queens, NY. I'm sure you can find and bargain down a good deal. G / L.
Old Aug 2, 2010 | 07:33 AM
2002MaxNJ's Avatar
The shop (Tire Barn Inc.) I usually go to thats really good is charging me $750 install and through car-parts found a place by me That had a tranny with 32k For $780 delivered to the shop by tomorrow afternoon. Rented a car at enterprise for about $65 w/insurance for the week but might not need it all week. Cant miss work you know...
Thank you guys for the help!!!!
Old Aug 2, 2010 | 07:50 AM
cajun1104's Avatar
I just put a re manufactured tanny from Transmission Planet in my 00 max, has a two year unlimited mileage warranty. It cost me around 1600 for the tranny and install. check out their site http://www.transmissionplanet.com
Old Aug 2, 2010 | 11:47 AM
Scottwax's Avatar
Install is a little pricey but if they do it right, between that and the cost of the transmission, you should get a lot of additional use out of your car for about 5 months worth of car payments.
Old Aug 3, 2010 | 06:13 AM
vastmax's Avatar
that seems awfully high for both the tranny and install price, I would expect MAYBE $1k total for parts and installation.
Old Aug 3, 2010 | 02:55 PM
DimaK's Avatar
wreking ard 400 bill
Old Aug 3, 2010 | 09:33 PM
Grand_hustle17's Avatar
Car-parts.com
Old Aug 4, 2010 | 04:40 AM
vastmax's Avatar
English....Do you speak it?
Old Aug 4, 2010 | 05:35 AM
yogi's Avatar
Old Aug 4, 2010 | 10:54 AM
max255's Avatar
How much would a new transmission cost with 0 miles?
Old Aug 4, 2010 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
It wouldn't be new, it be raman'd anyhow.
$2330.50 USD from Courtesy.
Old Aug 4, 2010 | 12:48 PM
yogi's Avatar
Old Aug 5, 2010 | 09:33 AM
bigpimpen092's Avatar
I just drove to PA from north jersey and bought an automatic transmission with 70k miles for 450 dollars.
Old Aug 5, 2010 | 02:32 PM
edgar5453's Avatar
My .02
I've been experiencing similar issues with my car, which at first felt as though my tranny was slipping. Now my car does did reverse and drive so thats a big difference, but doesn't necassarily take my tip out of the equation. For example i'd drive, and my transmission would shift fine, but all of a sudden my car neutralizes and begins to rev as though it is slipping. I would pull over park within a minute drive and the transmission would shift fine.
Took it to a Transmission shop (Eagle Transmission), and they hooked up their comp while reproducing the issue and came up with P1574 & P0720. Note my CEL never turned on so these codes were ones that lingered in the back that only specialized (expensive) comps could pick up. They also dropped the pan to ensure that there weren't any other symptoms of the transmisison going faulty. So the moral is the transmission wasn't the problem even when everyhting felt so, but rather the revolution(Speed) sensor which sits on the transmission.
My opinion before dropping a grand is check the tranny dip stick and smell for burnt oil, or have it either analyzed by a transmission shop or comp for any 'ghost' codes.
Edgar
Old Aug 5, 2010 | 10:26 PM
AngryHalfbreed72's Avatar
I just picked up a trans for $400.00 bux with 37k miles...thanks for posting up car-parts.com!!!!!
Old Aug 6, 2010 | 07:07 AM
cajun1104's Avatar
check out post number 12. that is where I got mine. (remanufactured)
Old Aug 12, 2010 | 09:10 AM
Saadkhan07's Avatar
I changed my trans fluid....and i overfilled it...drained all out, and put it back in ( a reduced amount) and after driving, it was bone dry...put some in last night, still looked like levels went no where. in the morning, it seemed overfull, and after driving, the levels were normal...but the car is driving a little harsh...any clues ?
Old Aug 24, 2010 | 01:38 PM
max2000ima's Avatar
DO NOT GO TO AAMCO. I went there for my 2000 Maxima SE and they diagnosed I needed a new tranny and they already had it out. They wanted to charge $750 to take the tranny out and put it back in. I had to find another transmission so they could put it in instead and they put on a cheap clutch, when they said it would be stock Nissan, and filled it with too thick of transmission fluid. It ran like crap and when I went back they said I needed another transmission, this one is bad.
Went to my buddy, who is a 120 miles away but is a nissan service tech, and he replaced the fluid and put a stock clutch in and the transmission has never felt so good.
Old Aug 27, 2010 | 11:22 AM
shaidarharan's Avatar
I just bought an '00 SE 5spd and I'm thinking about replacing my high-mileage (176k) tranny that has some whine in low gears and doesn't always go into 1st after starting up. Was thinking of getting a used tranny off car-part.com rather than rebuilding which I've had bad luck with in the past with other vehicles. I have a few questions as to which tranny to get, though.
1) how can I tell if my car has the LSD or not? I've heard you can find out by decoding the VIN, but I can't find a working VIN decoder anywhere (and yes, I've searched)
2) is the '00 model year transmission the only direct swap, or can I go with a tranny that has an LSD, such as the '01 anniversary edition?
3) if a tranny is listed has having a "non-locking diff" does that mean it has an LSD?
thanks in advance
Old Aug 27, 2010 | 05:14 PM
NmexMAX's Avatar
dot dot dot ...
thanks in advance
Odds are you do do not have an LSD.
If there is a "V" anywhere in your tranny code, then yes you do.
Old Aug 27, 2010 | 09:56 PM
b13ownr2's Avatar
[quote=shaidarharan;7710187]I just bought an '00 SE 5spd and I'm thinking about replacing my high-mileage (176k) tranny that has some whine in low gears and doesn't always go into 1st after starting up. Was thinking of getting a used tranny off car-part.com rather than rebuilding which I've had bad luck with in the past with other vehicles. I have a few questions as to which tranny to get, though.
Its like this..
non locking.... non LSD
1....... The drivers side where the axle comes out will have "bulge"... Non LSD is basically flat..... VIN gives you an idea, but a visual tells you proof positive whats there.... My 2 cents!!
thanks in advance
Old Aug 28, 2010 | 06:56 AM
Thanks for the answers guys, I don't think I have an LSD already but I'll check the plate you mentioned Nmex. What about the swap? What transmissions fit this car without modification?
Old Aug 28, 2010 | 10:59 AM
No "V" in my tranny code, as I suspected. Thanks for the info Nmex.
Old Aug 30, 2010 | 11:11 AM
Can anyone answer my remaining question? Which transmission(s) are direct bolt-ins for my car?
Old Aug 30, 2010 | 11:15 AM
scarface4522's Avatar
The transmissons the car was available with. either the 5 speed or the auto............
Old Aug 30, 2010 | 12:50 PM
Right... Except that a 5 spd w/LSD was an option. I'm asking if that will work without requiring modification. Same goes for the '01 model year.
Old Aug 31, 2010 | 08:37 AM
I realize this is probably a dumb question but I don't know the answer and I can't find it.
Old Aug 31, 2010 | 09:45 AM
NmexMAX's Avatar
dot dot dot ...
What is the question you are asking, specifically?
This might help:
http://forums.maxima.org/all-motor/3...swap-info.html
Old Aug 31, 2010 | 03:40 PM
This might help:
I'd like to find out which transmissions are direct bolt-ins for my car. Can I take a 5th gen 5 spd w/LSD and swap it for my tranny without any further work? What about a 5.5 gen 6 spd? Although if I go that route I'll probably just go all out and get a VQ35 as well.
Old Sep 1, 2010 | 11:31 AM
NmexMAX's Avatar
dot dot dot ...
You'll need axles for the VLSD if you go that route.
As far as the latter route, whole new bag'o'worms.
Old Sep 1, 2010 | 03:01 PM
Ok, thanks for the info. Any idea how much I could expect to pay for axles and where to get them? car-part.com has VLSD 5 SPDs for somewhere around $600-$700 but the axles listed on there have very little information so I imagine it would be hard to find them on car-part.
Edit: after checking again it looks like the only way to get a VLSD 5SPD off of car-part is to go for the 20th anniversary model and that raises the price dramatically. You can get a 6 SPD HLSD for the same price or maybe less.
