fight to solve the p0300 code!!
so my car like many others have that multiple missfire code come up once in a blue.... i askd a nissan tech about it and he sed its usually primay sensors on their way out or a failing maf sensor on its way out also...so im not replacing the maf lmao.... so im going to be doing (soon not right away) 2 brand new primary 02 sensors....04 rear vavle cover with new gasket and also all new coils... u guys might not think the coils or vavle cover is nesscary but i made the mistake to not change them when i installd my nwp spacers... the cylinder 6 coil felt gummy and had a lil bit of oil on it( might be causing the code also)
I have the same damn problem. I just need one new coil pack I think. I got the valve cover changed. I cleaned up the coil pack before put it in. I haven't checked it after that. I'm going to see if it still gets any oil in it. I ordered only one coil pack and change the one with oil spill in it. If you want to wait for me to get it done see if it solves that problem??
sounds good...either way im doing it anyway to prevent it if i do have oil in it even more...i only get the code when its rele hot outside( i have headers0 and my friend the nissan tech said the 02 sensors are prolly on their way out and not reading the a/f ratio good causing the misfire because they heat up to much and to fast from the headers...so weil see
I initially changed MAF also. Could tell a diiference in performace still had code though. Finally narrowed it down to Cylinder #2 misfire, changed ignition coil on #2 and it appears to have corrected my issue. Cleared the code and it has not returned (been 2 weeks now).
.any suggestions?
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
