Back to the Orange blinker mod
Old Aug 14, 2010 | 08:33 AM
showstoppa01's Avatar
I'am finally interested in doing the clearing orange blinker mod. No I not asking how to do it I just want to know if anyone here or know someone here that is selling those Malibu lens that is already cut to size perfect for a 5.5 2003 max?? I dont trust me and my hands doing that dremel cutting from Home Depot!!! Thanks
Old Aug 14, 2010 | 02:11 PM
5 ltr. beater's Avatar
WTF is an orange blinker mod???
Old Aug 14, 2010 | 03:05 PM
NmexMAX's Avatar
dot dot dot ...
If you don't trust yourself ( I also don't trust me), just leave it, no malibu lens needed.
Also,
http://forums.maxima.org/5th-generat...id-lights.html
Old Aug 14, 2010 | 03:15 PM
SoonerFan's Avatar
Cletus
its really pretty easy to do...and if you mess it up, that piece is cheap
Old Aug 15, 2010 | 09:38 PM
yankeefan13's Avatar
Yea Im wondering the same...
Old Aug 16, 2010 | 05:31 AM
Also,
Ya I was rhinking about that. However if i still wanted to decide i still may wanna see who out there can do it for me. $50 Going Oncee Going Twiceee Going Threee Times??????????????????????????
Old Aug 16, 2010 | 08:42 AM
tcaughey's Avatar
If you don't trust yourself with a dremel and some 'cheap' parts, I'd suggest staying away from modding your 'expensive' 5.5 gen headlights. Opening up the headlights AND properly resealing them once your finished is a bit more difficult than actually swapping out the orange lens.
Modding is WAY more enjoyable when YOU do it, and it's all about trusting yourself and your work. If your scared to try something, I'd suggest just stay away from it or pay someone for the labor.
Old Aug 16, 2010 | 12:44 PM
hacim105's Avatar
First, the lights from Home Depot are like $10 i think maybe less, at least they were when i bought them like 6 months ago (so money isn't that big of a deal, if you mess it up that bad you can get more for fairly cheap). Second, they are plastic and VERY VERY easy to cut up with the dremel (just remove the orange lens from the headlight, trace around it on the new lens and slowly trim around the traced circle, start off a little big and test fit, continue to trim down until you get a tight fit-very simple). Third, the Malibu lens is not a matching lens, it's frosted from what I understand and will not give you the look you are looking for.
Old Aug 17, 2010 | 05:47 PM
Actually the one from Tap Plastics is Frosted. I might just see who interested in doing this or just take the lens out and leave it clear and install a clear blinker
Old Aug 17, 2010 | 06:27 PM
One quick question. Does anyone know how long it takes when you re seal the light with the clamps/channel locks????
Old Aug 17, 2010 | 07:42 PM
hacim105's Avatar
You are right, the Malibu lens is from the light you buy from home depot. Just did a refresher search. There is no direct swap malibu lens. The direct swap talked about was the tap plastics lens which is frosted, and not desirable.
I didn't use any clamps/channel locks on my headlights. I just heated them back up in the oven and pushed them back together as best I could. It doesn't take long for them to cool off enough that the glue holds its form. The housing will still be warm but not hot enough for you to pull the headlights apart. This is a very simple mod. Just don't try to rush it
Old Oct 5, 2010 | 09:33 AM
ghostrider17's Avatar
Well - this is an odd bump.....
But I was JUUUST about to call Tap Plastics, until I found an actual PICTURE of what that piece looks like!
http://www.cardomain.com/ride/305093/2
No offense to this dude's ride....but I'm not too hip on that look.
I'm going the Intermatics & a Dremel Route. --and OFF I go to Lowe's!--
gr
JRod28
Dec 29, 2023 09:56 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
